Gearbox Oil Twincam RT
Re: Gearbox Oil Twincam RT
There is a lot of discussion on other forums to "suggest" that OEM BMW Synthetic OSP is relabelled Castrol SAF-XO. Also that the Castrol SAF-XO is factory fit. In 2010 when I bought my first Camhead, the supplying dealer gave me a BMW motorcycle lubricant recommendation chart. At the time, BMW recommended Castrol, EPX 80W-90 for the gear box and SAF-XO for the final drive. I believe the recommendation is now to use 75W-90 SAF-XO for both applications. Makes sense as 1 litre is sufficient for the gear box and final drive oil changes.
If the Castrol SAF-XO (or new equivalent) had been available when required, I would have bought it. On this occasion, I'll use Liqui Moly, I'm sure it'll be just fine.
After Castrol, Shell became the BMW preferred oil supplier. I don't think BMW make their own oil, Advantec (engine oil) is made by Shell.
Dreadnought
Has liked: 15 times
Been liked: 4 times
Post by Dreadnought »
David. wrote: Tue Dec 13, 2022 2:58 pm There is a lot of discussion on other forums to "suggest" that OEM BMW Synthetic OSP is relabelled Castrol SAF-XO. Also that the Castrol SAF-XO is factory fit. In 2010 when I bought my first Camhead, the supplying dealer gave me a BMW motorcycle lubricant recommendation chart. At the time, BMW recommended Castrol, EPX 80W-90 for the gear box and SAF-XO for the final drive. I believe the recommendation is now to use 75W-90 SAF-XO for both applications. Makes sense as 1 litre is sufficient for the gear box and final drive oil changes.
Who suggested BMW make their own oil, you missed the point
Motorworks currently have Castrol Gear oil 'Transmax Axle Longlife', 75W90 synthetic, 1 litre at a promo price of £15.90.
https://www.motorworks.co.uk/gear-oil-oia11056-1.html
Or, "Click & Collect" from Euro Car Parts for £17.99, https://www.eurocarparts.com/p/castrol- ... 20Products
Wuls
Bike Model and Year: 1200RT - 2008
Netherlands
Post by Wuls »
I only use the 75W/140 from Castrol. It's a bit thicker and runs fine on my R1200RT-2008 Gearbox and Final Drive.
My 2cents.
