Had a slightly wet but enjoyable Sunday. Had plenty of pig meat at breakfast, copious amounts of coffee, and a late lunch 😊
Then went home and carried on what's been rather a fishy week 😉
Ed Harley
Has liked: 16 times
Finland
Post by Ed Harley »
Went out for a ride today. Never before in November. 8-)
Bono estente!
Ed Harley
Has liked: 16 times
Finland
Post by Ed Harley »
Today we have been celebrating our 105th Independence Day.
Finlandia by Jean Sibelius:
https://www.youtube.com/watch?v=F5zg_af9b8c
Bono estente!
Looked out the window, saw the frost, then went back to bed
Ed Harley
Has liked: 16 times
Finland
Post by Ed Harley »
Today I was preparing myself mentally for the 6" of snow we will be getting tomorrow.
Bono estente!
Cork Truck Driver
Bike Model and Year: 2003 RT1150
Ireland
Post by Cork Truck Driver »
Completely new to this forum, a member recommended it to me. I’m from Ireland and bought a 2003 R1150RT in recent days. Just looking for all opinions positive abs negative on them. The one I have hasn’t been ridden in 18 months and the battery is totally flat. I did see/hear it when last on the road. Original battery was still in it. Damaged the fairing in the process. Doh!
Cork Truck Driver wrote: Thu Dec 29, 2022 5:28 pmBought a 2003 R1150RT. Just looking for all opinions positive and negative on them.
Not something I can help you with but hope someone else can.
In the models owned poll, only 2 out of 44 votes, viewtopic.php?p=7275#p7275
Ed Harley
Has liked: 16 times
Finland
Post by Ed Harley »
Cork Truck Driver wrote: Thu Dec 29, 2022 5:28 pm Completely new to this forum, a member recommended it to me. I’m from Ireland and bought a 2003 R1150RT in recent days. Just looking for all opinions positive abs negative on them. The one I have hasn’t been ridden in 18 months and the battery is totally flat. I did see/hear it when last on the road. Original battery was still in it. Damaged the fairing in the process. Doh!
I have had two R1100RTs in my time and in my opinion R1150RT is an improvement. Also aesthetically.
Don't know of the R1150 but R1100 was giving ABS faults whenever battery was bad or with low charge.
Is yours with singe or double plugs? The first one is in the middle of the valve cover/head and the other , if it exists, is under the head more or less vertically. I'm told that earlier single plug models tend to surge on the road but later double plug version cured this symptom.
Bono estente!
Greased the drive splines and renewed the bevel drive oil. Tomorrow am removing the tyres to start removing the flacking lacquer. Thinking of spraying them in Graphite grey. May do the same to the shaft and bevel housings. no sue yet
Doctor T wrote: Fri Dec 30, 2022 12:33 pmThinking of spraying them in Graphite grey. May do the same to the shaft and bevel housings.
It'll look like a 90th Anniversary model.
Ed Harley
Has liked: 16 times
Finland
Post by Ed Harley »
Doctor T wrote: Fri Dec 30, 2022 12:33 pm Greased the drive splines and renewed the bevel drive oil. Tomorrow am removing the tyres to start removing the flacking lacquer. Thinking of spraying them in Graphite grey. May do the same to the shaft and bevel housings. no sue yet
Sorry to bother but may I ask if there were any sign of internal corrosion etc.?
Bono estente!
Ed Harley
Has liked: 16 times
Finland
Post by Ed Harley »
David. wrote: Fri Dec 30, 2022 12:44 pm It'll look like a 90th Anniversary model.
Bike in that clip seemed to have Wunderlich hand guards which were discussed in other topic. Although they are a bit pricey they might be the best way to go ie. big enough and should fit without problems. :idea:
That is a nice color combo. 8-)
Bono estente!
Its a 2007 bike. No signs of corrosion on the spines.
Ed Harley wrote: Fri Dec 30, 2022 2:43 pmBike in that clip seemed to have Wunderlich hand guards which were discussed in other topic.
Yes, I spotted that too.
Ed Harley wrote: Fri Dec 30, 2022 2:43 pmThat is a nice colour combo.
IIRC, it was the last of the Camheads in 2013. I was tempted with one but having 2010 in Thunder Grey, didn't think there was sufficient of a colour change and a new model was due out in 2014.
