Spare blank Power socket front near side
- Bike Model and Year: BMW R1250 RT 2019
- Has liked: 2 times
Hi, does anyone know what this socket is for, it is located under the front fairing under the near side mirror, there are 3 cables going into it but the socket is blank on the inside and no pins are visible
- 2023-02-02 15.32.23.jpg (295.22 KiB) Viewed 9012 times
- 2023-02-02 15.32.17.jpg (208.64 KiB) Viewed 9012 times
Re: Spare blank Power socket front near side
I was thinking it was an AUX port but why would the internal of the socket have no pins to connect to, you can see the cables going into it but nothing on the inside...
- Been liked: 476 times
The cap/blanking cover needs to be removed from the plug/socket to expose the pins.
- Stu
- Has liked: 619 times
- Been liked: 598 times
As David says you will need to remove the blanking cover then it will connect to all the wiring for the AUX lights
It plugs in to the wiring connector just under number 9
- Bike Model and Year: 2018 r1200rt
What age is that bike?
I am searching for somewhere to plug in my nippy Normans cable for tomtom but cannot find a plug on my 2018
Quote from NN,[email protected] wrote: ↑Sun Feb 19, 2023 11:20 amI am searching for somewhere to plug in my Nippy Normans cable for Tom Tom but cannot find a plug on my 2018.
"the connector on the R1200RT LC is located in the area behind the meter panel. Need to remove windshield and a panel behind it to access."
https://www.nippynormans.com/gps-access ... mw-harness
- Been liked: 395 times
Take screen off and the panel underneath,as you stand in front of the bike the plug your looking for is to the right(presume its the same as my 16)Near the top[email protected] wrote: ↑Sun Feb 19, 2023 11:20 am What age is that bike?
- Has liked: 1 time
Thanks For the info
I took 12v power from it and installed a qi stand-charger for my waterproof mobile-GPS (Google maps)
Here are the 2 products you need.
https://motokinisi.gr/gr/bash-kinhtoy-g ... 07535.html
https://www.interphone.com/en-it/Holder ... TOWIRELESS
Hi. I hope this is the right place to ask this question. I have taken delivery of a new 2024 R1250RT. I read that the bikes have this spare power socket located between the handlebars and the left side mirror. Some use it for satnav. For those owners here in Australia, do our bikes have this cable ? If so could I use it to power my iPhone ? Any help appreciated. Have a safe Christmas/New Year.
Another question. Has anyone drilled or considered drilling a small hole into the phone cubby so that the USB could be used to power an iPhone mounted on the handlebars ?
Hi David. Thanks for your reply. Much appreciated. I hope so but I know that specs can vary depending on which country the bike is in. I had a look in that area but I couldn't see it. It may be well hidden of course. Looks like another question for the dealer. Cheers.
