Hand grip aftermarket
jackronner
Bike Model and Year: 2007 RT
Been liked: 11 times
Post by jackronner »
I've been getting a painful callus at the base of my pinky from the throttle grip. I'm thinking of getting a thicker and softer replacement. Anybody know how hard it is to remove and replace the original hand grip, or if there is an aftermarket product that will fit over the existing grip? Thanks.
Tenequip
Has liked: 8 times
Been liked: 8 times
Re: Hand grip aftermarket
Post by Tenequip »
I have used foam rubber slip-on grips for all my bikes for years. They usually cost about $8 or $10 and slip on easily with a little liquid dish soap.
Tenequip
Funny enough I put my grip puppies on yesterday.As Tenequip says,a little soapy water and they slip over the original grips no problem :thumb:
Just measure and cut to the required length, soap em up and slide them on.
Has liked: 617 times
I used these, a bit thinner than puppies, might get another pair to try again 🤔🤣
https://www.amazon.co.uk/gp/product/B09 ... UTF8&psc=1
Has liked: 1433 times
Every bike ive owned except an R80Rt( they had oblong grips) has had grip puppies fitted. If you have heated grips with GP slipped over them you will still feel the heat.
tag2501
Bike Model and Year: fjr1300 2006
Post by tag2501 »
had them on my FJR for year - cured some high frequency vibrations nicely. putting them on he new 1250RT. they really do help reduce hand and finger fatigue on longer rides. also IMHO improve throttle control.
jackronner
Thanks, all. Are the regular Grip Pups OK for the RT, or will I need the "Big Paws"? Also, since the OD on the Beemer grips taper down towards the inside, will the GP's conform tightly, or do they gather a bit at the smaller end?
Just buy the normal puppies and they fit perfectly, as long as you measure and cut them correctly. I never went tight to the wheel,left a couple of mm gap and they look spot on.One thing I will say,cutting them with a Stanley blade pulled the sponge a bit,if I did them again I would get a long sharp blade and cut like a guillotine to give a sharper finish :thumb:
jackronner
Ordering them now, with your "incisive" advice in mind.
Totaled TL
Been liked: 9 times
Post by Totaled TL »
Bought some generic foam overgrips from Amazon. Used compressed air and small piece of tubing. No soap needed.
jackronner
Just installed the regular sized Grip Pup on the throttle and it feels great. It also fits tightly over the tapered thinner OD of the inboard side of the grip. Had to use WD 40 since the soapy water didn't cut it. Strange how the minimally greater circumference makes the throttle more sensitive and jumpy, which I suppose I'll get used to before long. Goodbye calluses, and I'm sure it will make longer trips less tiring and crampy for my right hand. Thanks for all the input.
Totaled TL
Been liked: 9 times
"Strange how the minimally greater circumference makes the throttle more sensitive and jumpy, ..."
Shouldn't it have the opposite effect?
Your hands will get used to them quickly. At the moment you are just feeling hand and finger muscle memory.
Tenequip
Has liked: 8 times
Been liked: 8 times
Post by Tenequip »
Correction to my earlier post: Noticed that everyone is using soapy water when they install the grips, I use the liquid soak straight up no water added. Never had any trouble getting the grips with the liquid soap straight up.
Tenequip
Has liked: 473 times
Been liked: 404 times
There was a post on this site about a Chinese made ‘old RT’ type grip that really caught my fancy, so a I spoke to my specialist BMW mechie about it… pursed lips and an “Ooohh, be very careful” uttering quickly followed :| together with “they’re over a hundred quid if you get it wrong”
If he’s unhappy to do it then I certainly won’t… shame. :(
