Top box case
Has liked: 154 times
Top box case
Ok. am i going mad, but why is there no handle on the BMW OEM large top box.
I took mine off yesterday so i can start removing the bodywork.
I found no handle and because of the size it was a pain to carry indoors.
Re: Top box case
Am positive it should have a pop-out handle above the locking flap
Re: Top box case
Nope, no handle.
No Handle Top Box Case.jpg (308.73 KiB) Viewed 2185 times
Re: Top box case
Re: Top box case
Same on mine! no handle so its a pain in the arse
tewatson
Been liked: 6 times
Re: Top box case
Post by tewatson »
Probably because the designers did not expect it to be frequently removed and carried around. What with a wiring harness and all it’s not really a quick and clean process as with the panniers.
Tom
OscarTGrouch
Has liked: 4 times
Re: Top box case
Post by OscarTGrouch »
The older 49L top box has a handle, the newer 49L Top Box has provisions to install a additional brake tail light. I've have both and would prefer the light. Although they should have figured out how to make half of that light to blink with the turn signal too.
2023 R1250RT :lol:
2022 R1800TC gone :)
2016 R1200RT w/c gone :)
2014 K100GTL (gone) :(
2014 R1200RT w/c (gone) :(
2005 R1200RT Hex head (gone) :(
Re: Top box case
OscarTGrouch wrote: Wed Dec 20, 2023 5:19 am The older 49L top box has a handle, the newer 49L Top Box has provisions to install a additional brake tail light. I've have both and would prefer the light. Although they should have figured out how to make half of that light to blink with the turn signal too.
I knew the box had a carry handle, admittily the older version.
Kim_Y
Been liked: 7 times
Re: Top box case
Post by Kim_Y »
Correct, my top box has a handle. Funny thing is, since I've installed this top case, I've never had a need to remove it. So convenient to easily store 2-helments.
BMW Top Case Pic.jpg (108.29 KiB) Viewed 2056 times
-Kim Y.
