Hello all
After working fine previously, the cruise control switch on my 2011 RT has developed an intermittent fault. Essentially; sometimes it works, sometimes it does not. There's no real pattern to it, like the weather etc. I've sprayed the gaps at the edge of the button several times with electrical cleaner, then some WD40, but it's still very unpredictable whether it works or not.
Does anybody have any suggestions of the cause and possible remedies?
Many thanks
Cruise control switch problem
- Has liked: 1433 times
- Been liked: 406 times
Re: Cruise control switch problem
If it's like my 07 bike the CC cables are often overlooked on services. I had to change mine as the inner cables had frayed. The clutch switch is your best bet to start with
