Fuel line replacement
- Bike Model and Year: 06 r1200 rt
I've had the misfortune of a rodent chewing through some wiring which I've repaired to discover it also made a small scratched hole in a fuel line. I've got the replacement that includes pressure regulator and 4 way lines with distributor. The lines seem to be shrunk fit, I'm wondering if there's any way to remove and replace just one to avoid replacing the whole 4 way?
- fuel pressure regulator
- 17127236007813830626419226611324.jpg (202.28 KiB) Viewed 1971 times
- fuel lines
- 17127235728007798688037296258261.jpg (184.18 KiB) Viewed 1971 times
- Has liked: 1428 times
- Been liked: 406 times
Re: Fuel line replacement
It may be a very tight fit but try putting the line in boiling water to soften it up. It may work or may not
