Aftermarket levers
Has liked: 617 times
Aftermarket levers
I’m happy with the shape of the stock levers on my 1250 but ideally would like a reach distance on the clutch between position 1 and 2 and on the brake something closer to the bar than position 1.
Are there any “sensibly priced “ adjustable levers out there that would do the job ?.
Re: Aftermarket levers
I replaced mine with a set of wunderlich levers and they are 1000 times better than stock
Yes they are expensive but worth it for me
Thanks I’ll take a look 🙏, do they have click adjustment or infinite?.
Has liked: 473 times
Been liked: 404 times
Hi Martin, this is an older thread that may be of help:
viewtopic.php?t=6563
Panman40 wrote: Sat Apr 20, 2024 7:36 am Thanks I’ll take a look 🙏, do they have click adjustment or infinite?.
They are a span adjuster similar to the stock one but with 6 positions
sakm wrote: Sat Apr 20, 2024 9:00 am They are a span adjuster similar to the stock one but with 6 positions
Cheers, one of the first reviews from nippy Norman’s mentioned that the brake lever doesn’t bring the reach closer to the bars as in the description though :( , this would be the only reason for me swapping out.
Panman40 wrote: Sat Apr 20, 2024 10:41 pm Cheers, one of the first reviews from nippy Norman’s mentioned that the brake lever doesn’t bring the reach closer to the bars as in the description though :( , this would be the only reason for me swapping out.
Remind me if I haven't replied in a day or so and I will measure the distance for you :thumb:
@Panman40
This measurement is on both brake and clutch at the closest point to the bars between position 1 and 6
It's pointless measuring at the ends of the lever due to them being adjustable and different length
The main point is where you would grab the lever
As you can see they are about the same on both sides
So just measure your levers now to see the difference
sakm wrote: Sun Apr 21, 2024 6:57 pm @Panman40
Thanks for taking the time to do that 🙏, I’ll have a measure up !.
Looks as if the stock 1250 brake lever is closer to the bar than the Wunderlich :shock:
So I went with ASV standard length levers in silver, very happy with the outcome, just be careful when swapping the barrel and pushrod of those 2mm Allen grubs covered in loctite :roll:
So went with ASV in silver, happy but watch out with swapping parts over as those BMW 2mm Allen grubs covered in loctite are ….
No idea why images don’t upload properly?
Panman40 wrote: Sun May 19, 2024 8:28 pm No idea why images don’t upload properly?
Not sure what's going on there! I will have a look and see if I can see anything
sakm wrote: Sun May 19, 2024 8:39 pm Not sure what's going on there! I will have a look and see if I can see anything
Cheers, no idea lol, just images from my iPhone, it didn’t say file to large etc.
