What happened? Wouldn’t start
Pietro Rosso
Post by Pietro Rosso »
Hi
Can I have some advice please?
R1250RT 2021 on a trip this morning. Had to stop after an hour of fast A roads and then it wouldn’t start. Barely turning over and wouldn’t catch. Volts reading as 12.0.
I tried it a couple of times and it was the same. Left it 20 minutes and it started fine.
Any help appreciated…
Re: What happened? Wouldn’t start
It could be the same hot starting problem as some of the 1250GS.
I think they replaced the starter solenoid or cleaned the contacts.
Have a look on UKGSer.
michaelc2710
Has liked: 66 times
Been liked: 76 times
Post by michaelc2710 »
Hi
You will probably find it's the battery.
They had a problem around 2020-2021 of batteries getting warm and internally shorting, once left to cool down it would start again.
It's the start of it giving up, there was a batch / battery number that was effected but I can't remember it now.
Do a search on here and you should find it.
This thread may be helpful, viewtopic.php?t=6039&hilit=compression
Pietro Rosso
Many thanks for replies.
I’ll get it checked out.
