General Advice Please
Peter1
Post by Peter1 »
I have £4k to spend on a BMW RT can you advise, 1. which model and year I should consider, what issues should I look out for, and can you recommend a great value insurer. Much appreciated. Pete
jesim1
Has liked: 142 times
Been liked: 85 times
Re: General Advice Please
Post by jesim1 »
Welcome to the forum, sadly the RT is not a cheap bike, so with your budget your going to be driven more by what you can get than what you should be looking for unfortunately :oops:
Just check all the consumable parts like tires, brake pipes, seals and especially the drive shaft for potential replacement as these could quickly add up :cheers:
Personally, and I'm sure I'll be flamed for this, I'd have a look at an FJ12/GTR1400/VFR1200 etc as I think you will get a newer one for the money :roll:
Peter1
Post by Peter1 »
Thanks I'll take a look at those also.
The vfr1200f is a great bike. but any of the above are good.
Peter1
Post by Peter1 »
Thanks, I am still liking the BMW as I believe the CofG is lower and also need comfort rather than sporty.
EasyRider wrote: Mon Sep 02, 2024 12:27 pm The vfr1200f is a great bike. but any of the above are good.
Great engine(I had one before moving to the RT)the rest is pretty much pants for a sports tourer.
Has liked: 99 times
Been liked: 225 times
Peter1 wrote: Sun Sep 01, 2024 8:31 pm I have £4k to spend on a BMW RT can you advise, 1. which model and year I should consider, what issues should I look out for, and can you recommend a great value insurer. Much appreciated. Pete
I'd go for a 2010 - 2013 Twin Cam model if you can find one within your budget.
Peter1
Post by Peter1 »
Thank you, much appreciated.
Pannier Down
Has liked: 3 times
Post by Pannier Down »
+1 on the twin cam. Gets you into the more modern switchgear and away from wine gum indicators. Decent engine too.
