Specks of Tar.
Has liked: 17 times
Been liked: 134 times
Specks of Tar.
I gave my R1250RT a panels off really good wash today and noticed quite a lot of specks of black tar stuck to the (silver) engine case, rims and assorted other places. I know the likes of Autoglym sell 'Tar Remover' but before I buy some of theirs (or similar), can the hive mind confirm it's okay to use on the Silver paint BMW use on ther engines & assorted other parts.
https://www.autoglym.com/intensive-tar- ... 500ml.html
Re: Specks of Tar.
No idea of that stuff,I use diesel gently rubbed in.
Sorry it doesn't answer your question,will be intrested in the results.
Has liked: 80 times
Been liked: 87 times
Re: Specks of Tar.
Post by Sullivj »
I use the Autoglym tar spot remover and have not had any issues with it.
Has liked: 17 times
Re: Specks of Tar.
Sullivj wrote: Wed Nov 13, 2024 3:50 pm I use the Autoglym tar spot remover and have not had any issues with it.
Cheers.
Mart UK
Has liked: 35 times
Been liked: 24 times
Re: Specks of Tar.
Post by Mart UK »
I use WD40, it loosens and dissolves the tar, then can be wiped off with a 2nd squirm of WD40, or a foam wash.
Has liked: 1433 times
Re: Specks of Tar.
Meths or white spirit works and is a lot cheaper
Re: Specks of Tar.
Paraffin is a good cheap alternative too :)
DaveCly
Has liked: 74 times
Been liked: 51 times
Re: Specks of Tar.
Post by DaveCly »
I’ve used it with no problems, if it’s not to stuck on GT85 does the job on the rims.
jesim1
Has liked: 142 times
Been liked: 85 times
Re: Specks of Tar.
Post by jesim1 »
As above, any light petroleum based liquid should do the trick and is easy to come by, just don't rub too hard and make sure you wipe it off afterword's :cheers:
Shuswaper
Has liked: 3 times
Been liked: 8 times
Canada
Re: Specks of Tar.
Post by Shuswaper »
Varsol, works like a charm.
