Have re-voted, now in the 50 to 55K bracket.
Survey of RT mileages
- Bike Model and Year: 2020 R1250RT
Re: Survey of RT mileages
167K on my 2012 RT when I traded it in for a 2020 and it was still runnin smooth. Only repair was a new clutch at 102K
- Been liked: 476 times
Another high mileage Camhead.
bruce2000ltc wrote: ↑Mon Nov 18, 2024 6:48 pmI've owned my '13 RT since Feb 2014, bought it new. It's got 91,000 mi on it now.
- Steve398
- Has liked: 473 times
- Been liked: 403 times
Just updated to 37,000 on my 2018. My wife recently commented that I’m using the RT far more than my previous ST1300…. working it out (and including 2 Covid years with lockdowns) I’m putting about 7,000 a year on the bike.
- Stu
- Has liked: 619 times
- Been liked: 598 times
Good point!
Just updated mine! Same mileage too and averaging the same per yer
- Bike Model and Year: 2014 R1200RT LC
- Has liked: 3 times
- Been liked: 2 times
- Bike Model and Year: 2017
- Has liked: 225 times
- Been liked: 102 times
- Been liked: 4 times
Recently replaced fork seals as one was leaking.
Replaced clutch at 95,000 miles.
Front brake pads once, rear brake pads 3x times.
Timing chain tensioner due to oil leak.
Fuel pump under warranty due to recall.
Coils around 70,000 miles.
Other than that pretty much just regular and religious maintenance according to recommenced intervals.
Oil changed at 5000 miles, differential fluid change about every 12,00 miles with driveshaft check and lube splines, gearbox oil changes every 24,000 miles as with spark plugs, brake fluid every 2 years. Lube and check other components on a regular basis. I have a pretty big spreadsheet record of all maintenance and repairs. Tires usually done every 11,000-12,000 miles.
I purchased with 53,000 miles on it so not sure if any problems before that but was told it was well maintained.
- Bike Model and Year: R1250rt 2021
- Has liked: 2 times
- Been liked: 9 times
Bought my 21 plate in May 23 with 5,000 miles on the clock, it now is just shy of 32,000!!! Costing me a small fortune!!
Does include two European summer trips of over 4,000 miles each! (Two up and camping gear!)
However, I just love the bike
how much it is worth now I dread to ask!!
2021 R1250RT LE Blue
