Newbie here,
My 2014 R1200RT has a weeping issues after a hard ride and also after sitting in the cold garage for a number of days. I'm planning to just replace the water pump unless someone tells me otherwise. Also, not many solid videos on Youtube, does anyone have a good source for aiding me in the replacement?
Thank you!
Keith
Water pump replacement/weeping
- Stu
- Has liked: 619 times
- Been liked: 598 times
Re: Water pump replacement/weeping
Hi and welcome to the forum
Looking at the manual its fairly easy to replace the waterpump its just the front cover off and remove the pump that's hiding behind it
Have a look at the file attached
- Waterpump.pdf
- (359.23 KiB) Downloaded 99 times
