Carpuride system
- Steve398
- Has liked: 584 times
- Been liked: 490 times
Re: Carpuride system
I’m putting my Carpuride W502B Pro up for sale soon as I’ve managed to get my Tomtom to stop interrupting and ‘bong bong-ing’ with the sat nav notifications.
Bought in Dec ‘24 but not used until the sun shone, so new and used maybe six times, but too technical for my aged faculties.
PM me if interested, I’ll put an add up in the For Sale bit when I get time. It’ll be £125.
binhetveld
So I installed the navigation. Looks wonderful, fits great. I can't seem to change the layout from Android Auto. The buttons are at the bottom while I want them on the left side. I have this layout in the car, so it should be possible. But how?
Does anybody know how to change this?
So I’ve been playing with the W502b on my 1250rt, first impressions are it’s to small to see properly but I really only bought it out of curiosity, I use an iPhone 15 so it’s CarPlay, at first I couldn’t get any audio at all for music or maps etc so a quick google said to change the BT option and that seemed to work, now when I say scroll left or right that doesn’t work, any ideas ?.
2, unit boots up when ignition turns on instantly but when pressing the starter it shuts down and then reboots, any fix for that annoyance ?.
3, any way to have the maps voice louder without increasing music volume ?. I’ve tried upping the sena srl whilst she’s talking but then music is to loud
Also the only screen protector I can see online is from Germany….
- S2NAZ
- Bike Model and Year: R1200RT 2015
- Has liked: 6 times
- Contact:
Question on the Carpuride. I see now there is an adapter for the 7” Carpuride sold on EBay and wondered about the cabling in the pictures, is that part of the Carpuride or part of the existing mount that comes from within the bike dash area that’s hidden? Anyone have a link to a you tube video perhaps that shows the install of the system or installation instructions? Thanks! ~Stew
Back in the saddle again!
Not much happening in this thread it seems, I wondered that too and can’t really make head nor tail of that adaptor on eBay.S2NAZ wrote: Tue Apr 08, 2025 4:21 pm Question on the Carpuride. I see now there is an adapter for the 7” Carpuride sold on EBay and wondered about the cabling in the pictures, is that part of the Carpuride or part of the existing mount that comes from within the bike dash area that’s hidden? Anyone have a link to a you tube video perhaps that shows the install of the system or installation instructions? Thanks! ~Stew
azbimiller
- Bike Model and Year: R1200RT LC 2014
Here is another take, similar to what VR46 did in an earlier post:
I was disappointed with the small screen on the Garmin (ZUMO 660) and really wanted Apple car play for mapping on the bike. I wasn’t concerned with music to the bike stereo or Wonder wheel operation.
Here is my solution: I Purchased a Carpuride C92 from Amazon ($118.00 US in March 2025 price is down to $85.00 US as of end of April). It’s not waterproof and doesn’t have forward facing camera. As this was an exercise in “proof of concept” I wasn’t concerned about either option. It does have a backup camera which I haven’t installed yet. For the price point I wasn’t expecting a lot and if it didn’t work I wouldn’t be out much. To date I’ve been very pleased with its performance, fit and function. It has 9.3” viewable area, powered by USB-C cable delivering 2.0 Amps. For the mount, I wanted to create one that would use the existing factory GPS mount for a sterile look and feel.
With an engineering education and experience 3D modeling in SolidWroks as well as a 3D printer I went to work.
The base snaps into the factory GPS mount on the bike and ball fits in the cup of the mount that is included with the display. A brass heat set nut was installed in the ball and a 6mm aIlen headed bolt tightens it all together. There are two small O-rings used to create some friction and mild dampening within the mount.
"Ball.jpg" and Main Mount.jpg show the model parts and part2.jpg shows the assembled mount.
I used ASA/CF (Acrylonitrile Styrene Acrylate) material to print the mount. This is Carbon Fiber reinforced ASA. This material is similar to ABS with very good weather and UV protection. Also, it looks better in a matt finish IMHO which the CF provides. Most users with 3D printers should be familiar with this material.
Part3.jpg is the back side of the display with the mount attached.
This display is powered from a USB-C cable at 2.0A. I tried using the USB outlet in the right glove box but it would not work, the display would continually power cycle. I suspect due to marginal current. I added a surface mounted USB-C port in the right glove box. It’s hardwired to the DIN power socket on the right side. The USB cable exit’s the glove box via rubber grommet and routes behind the dash and exit’s next to the GPS mount.
Items of NOTE:
To power the display, I installed a switchable USB-C surface mount adapter. It is powered from the DIN socket (hardwired in) on the right side of the fairing. I can manually switch when the ports are on or off. The power adapter is in the right “Glove box”. With the USB connector and audio port already in that box is not good for much of anything anyway. I punched a hole on the inboard side of the box and ran the USB cable through a rubber grommet. The USB-C able runs behind the dash and comes out next to the GPS mount. I used a cable with a 90 degree end so you do not see the cable when connected.
This display is NOT waterproof. Some of the Carpuride ones are but this one is not. I live in the desert so rain is rarely an issue. Reviewers have complained about the audio quality but as mentioned audio is not an issue for me, won’t us it. So far I'm very pleased with the exercise. This does not work with the Wonder-wheel!
Rode to work this AM and could see the map just fine even in the rising morning sun. Full sun in the afternoon was even better. For my sub $130 investment and some time with the 3D printer I could be happier. If anyone has access to a 3D printer and wants the STL files I am happy to share them for free. :cheers:
For some reason the images wouldn't attach in the text.
Items of NOTE:
- displayRT.jpg (133.62 KiB) Viewed 5543 times
- part3.jpg (263.79 KiB) Viewed 5543 times
- part2.jpg (221.03 KiB) Viewed 5543 times
- parts1.jpg (35.9 KiB) Viewed 5543 times
- Ball.JPG (22.49 KiB) Viewed 5543 times
- Main mount.JPG (64.82 KiB) Viewed 5543 times
- Has liked: 1695 times
- Been liked: 549 times
These printers are brilliant at what they can make. The nearest I got to them was a lathe
Howelligan
- Has liked: 37 times
- Been liked: 10 times
Hey Robert, Out of interest, did you have any issues with the 502B 'connecting' with your bike's EMS (Engine Management System)? I just got one & while it powers up OK, & is more or less happy enough to do stuff via the Android Auto App, most of the time, it is staunchly refusing to link to the bike, so none of the features on the 'Home Screen' are available. =-(
- jclaudej
- Bike Model and Year: 1250 RT 2019
- Has liked: 11 times
- Been liked: 17 times
- Contact:
Hi from France,
I used a Carpuride W502B pro since one month and perhaps I can help you about the restart of your carpuride when you restart your engine.
This problem isn't in relation with the Carpuride but only with power supply from your bike who cut it during the start of your bike.
But this problem is similar with all solution who use the GPS kit of BMW. for example Wunderlinq met this problem and sometime I must restart my smartphone if I want use it.
I hope that my explanation will be clear for you
Fourbears
- Been liked: 8 times
Well I bit the bullet and got the 702. I also got the adapter from EBay (https://www.ebay.co.uk/itm/167047695149) which it mounts to very well. The cabling is hidden within and behind the adapter and uses the OE sat nav mount for power. It boots up quickly and does briefly go off when starting but that is because I think the electrical system cuts the power, similar to all my cars. I use it with Myroute App for navigation and it works really well, once you have started navigation on your phone. I use CarPlay so can’t comment on Android Auto. Screen is a good size, easy to use and responds quickly to gloves. Overall I’m pleased and at the moment can’t see me going back to my Garmin XT.
I haven’t used the bike much since June but popped the 702 on for a short ride on Friday, the screen is good and clear, it’s very annoying it doesn’t have its own battery which woukd avoid it switching off when starting the bike but it’s no big deal.
One thing that is annoying though that Siri on my iPhone via my Sena headset seldom works for voice commands. Any tips ?.
