R1200RT Mods
MisterB
R1200RT Mods
Post by MisterB »
Hi all,
I'm about to move from an 07 R1200GS to an 11 R1200RT :-) Are there any mods you guys think are essential or really worth doing to the RT please?
Re: R1200RT Mods
On mine I fitted the OEM engine protectors and the impact protectors for the pannier lids.  The lids are £250 a time, the plastic/rubber protectors I remember were about £50. Also swapped to a one piece comfort seat again BMW .  Some like covering the tops of the pannier lids with clear plastic. I never did as it looks ugly and its not difficult not to kick them. You could also fit a fender extender.
Maz12
Re: R1200RT Mods
Post by Maz12 »
RTman10 wrote: On mine I fitted the OEM engine protectors and the impact protectors for the pannier lids.  The lids are £250 a time, the plastic/rubber protectors I remember were about £50. Also swapped to a one piece comfort seat again BMW .  Some like covering the tops of the pannier lids with clear plastic. I never did as it looks ugly and its not difficult not to kick them. You could also fit a fender extender.
Plus 1 for the comfort seat (which I happen to have going spare)  and the fender extender too,  I also had the pannier impact protectors which are ok but don't stop the pannier getting scratched if you lay the bike down ( as I found out)
MisterB
Re: R1200RT Mods
Post by MisterB »
Is the comfort seat in 2 parts or a single unit? I would have thought a bike designed as a long distance tourer would have had a comfortable seat but clearly not!
Maz12
Re: R1200RT Mods
Post by Maz12 »
The comfort seat is a single piece,  it sits a little lower than stock but is a bit wider
Re: R1200RT Mods
Maz12 wrote: The comfort seat is a single piece,  it sits a little lower than stock but is a bit wider
Its 775mm high but much wider for the pillion.  Wife insisted it was the most comfortable seat she had ever had.  Height is unadjustable as you have to remove the bits on the bike that make the two piece adjust. Best mod you can get though if you find the stock seat uncomfortable, most don't.
beemerbaz
Re: R1200RT Mods
Post by beemerbaz »
RTman10 wrote: Its 775mm high but much wider for the pillion.  Wife insisted it was the most comfortable seat she had ever had.  Height is unadjustable as you have to remove the bits on the bike that make the two piece adjust. Best mod you can get though if you find the stock seat uncomfortable, most don't.
I have the comfort seat and love it for it's support on the lower back. That said, no mater what you sit on after a time it will still feel like concrete. I did 1000 miles in 2 days returning from Austria and was glad to get off.
chrismckay
Re: R1200RT Mods
Post by chrismckay »
I also have the comfort seat which I like, inner bags for the panniers is also convenient....
Wierpig
Re: R1200RT Mods
Post by Wierpig »
I would say a footrest lowering kit and Wilbers wesa if you have ESA.The standard shocks are so crude in comparison.I have some for sale as off to LC  8)
