Hi there. I'm new to this forum. I have a r1200rt on a 2006 plate. I have the dreaded abs problem. I have done extensive testing on the modulator and come to the conclusion that the rear side of the circuit board is faulty. Anyone know where I can buy a new circuit board or get mine repair.
Peter
ABS Modulator issue
- Been liked: 145 times
Re: ABS Modulator issue
If you are not successful in getting a new circuit board or yours repaired, would a used unit be any help.
Looks like Motorworks sell used ABS Modulators (subject to availability & condition) with some sort of warranty:-
http://www.motorworks.co.uk/vlive/Shop/ ... 0_35_HA_70
Hi dayglo david.
Thanks for your reply. I have checked out motorworks but still the price is quite high £500 for a recon unit. Ideally a new board would be the cheapest way. Thanks for your help and if you have any other leads or thoughts in the future I would be most grateful.
Ps. Would you happen to know anyone that re conditions these units in the UK because I could get a new from them.
Cheers
Happy new year
Pete
Cheers
Happy new year
Pete
Why dont you have a look at BMWs Real OEM site. It wont give you prices but it will show what is available new. Having spent some years at a dealership I can only remember bringing in completed units. With your bike having servo brakes I think your search might be a difficulty one as they have been out of production for 8 years..
This link can be used to download a BMW Electronic Parts Catalogue, it may be some help.
http://www.bmw-motorrad.com/com/en/inde ... _main.html
A&S BMW Motorcycles Parts Catalogue is only showing the Modulator as a complete unit, which one is yours.
http://www.ascycles.com/Illustrated_cat ... =Brakes#34
Pressure modulator Integral ABS
Pressure modulator I-ABS Generation 2
Hi dave.
Thanks for your response.
I have the top one the abs III system. I do have some leads now to find the board. I could just buy a complete unit but still you don't really know what you're buying and how good of condition it is. Trust me to buy a bike with the old system. The issue I have is that I know it's only the circuit board as I have tested all the hydraulic side (fine) and the electrical side on the pump it self ie: motors switches etc are all fine. Someone has made this part initially also you can get these pumps reconditioned so you must be able to get the board. I'll have a look at the link that was sent to me and see if that is of some help.
Thanks for responding though. I'll keep you guys in touch with my findings and I will post pictures etc of the pump and how to service it as it's dead easy.
Speak soon
Speak soon
Correct me if I am wrong, but is it an option to carry out an ABSectomy and just run with normal brakes ? I have heard of this being done at a fraction of the cost.
Unfortunately on the servo version's no ABS pump means residual braking (bugger all) only.beemerbaz wrote: Correct me if I am wrong, but is it an option to carry out an ABSectomy and just run with normal brakes ? I have heard of this being done at a fraction of the cost.
Hi there. Yes I can. Motorworks supply a kit to reverse to a standard breaking system but I want the abs. I have a bike with that system and don't really want to lose it.
The thing is I do still have some residual braking in the rear brake but the front hasn't been affected at all. Full braking. I might not have abs to the front but I have braking.
Interesting that your front brake has full power. Do you still get the servo pump noise when you pull the lever and have you had the problem diagnosed at a BMW dealer ?
"Re-plumbing" an ABS brake setup back to a conventional system shouldn't be a big problem and, after following the "BMW ABS Modulator Saga" for six or seven years, I have read where this isn't unusual in some countries and/or states (some brake repair companies advertise). But please be careful with the legalities. I have read on some forums that different countries/states have different regulations. I know that in my country, the Australian Design Rules (the dreaded ADRs) are very strict on "correct ABS operation with respect to the make and model of vehicle originally being passed for import". Re-plumbing an ABS setup back to a conventional system is a big no-no in Australia - and worse - selling a vehicle with an altered ABS setup could land the vendor in a lot of trouble. Insurance coverage could be a problem in the event of an incident, if the ABS has been bypassed to a conventional braking system.beemerbaz wrote: Correct me if I am wrong, but is it an option to carry out an ABSectomy and just run with normal brakes ? I have heard of this being done at a fraction of the cost.
I regard the entire BMW ABS debacle as a thorough PITA.
Just my AUD $0.02 worth (which equals GBP 0.0106 on today's exchange rate). :-\
2012 R1200RT, 1994 R100LT and 1988 R100RS
