Stalling issues
- Bike Model and Year: 2011 r1200rt
- Has liked: 8 times
Stalling issues
For the second time in a month and a half my '11 rt has stalled, flamed out while coasting up to a stop sign to make a right hand turn. Weird. Clutch in and coasting. It starts right back up but it shouldn't be happening. Also it will burble and hesitate every once in a while I blip the throttle before leaving a stop light. What in the hell?
Re: Stalling issues
Don't approach stop signs or turn Right - open up the throttle and keep straight on, or turn Left only :alas:slowvet wrote: For the second time in a month and a half my '11 rt has stalled, flamed out while coasting up to a stop sign to make a right hand turn. Weird. Clutch in and coasting. It starts right back up but it shouldn't be happening. Also it will burble and hesitate every once in a while I blip the throttle before leaving a stop light. What in the hell?
( Sure our `Guru' RTman10 will have the answer and can help you out )
Re: Stalling issues
When the twin cam first came out they had a recall for just your problem. Bike would suddenly stall. A small replacement part I recall on valve gear fixed the problem. Contact any dealer who can quickly check if your bike is an effected one. If so its a quick warranty job to fix.
- Been liked: 145 times
Re: Stalling issues
Was that a Cam Sensor modification.RTman10 wrote:A small replacement part I recall on valve gear fixed the problem.
Re: Stalling issues
Probably, cant quite remember. Once had a stack od them in a plastic bag, looked like a big washer with a small lug on it. Original ones had no lug.DaygloDavid wrote: Was that a Cam Sensor modification.
Re: Stalling issues
Removing the RHS Valve Cover will reveal whether or not this replacement part has been fitted.
Re: Stalling issues
Good clear detail DaygloDavid, how the hell do you manage to find all this obscure stuffDaygloDavid wrote: Removing the RHS Valve Cover will reveal whether or not this replacement part has been fitted.
( keep it coming though, well done)
Re: Stalling issues
Called the service tech today and explained what was happening. I think I'm facing an up hill battle. I didn't mention recall, was hoping he would have said or mentioned what RTman wrote above. Would the problem come up in a code check? I plan on taking it for a long ride tomorrow on some back roads and see if it stalls when I randomly coast up to some stop signs. I also mentioned the off idle throttle belch/burble when I'm sitting at a stop light when I give the throttle an 1/8 turn blip. His reply, don't blip the throttle....at all. And Selyn, I heard that!
Re: Stalling issues
A 2011 Bike with 12,000 miles, what's the Service History, 12K Service Schedule:- https://www.ascycles.com/pdf/ServiceSch ... ervice.pdf
Valve Clearances, Spark Plugs, Air Filter & Engine Synchronisation (Throttle Valves) may all effect the Engine performance.
The Independent BMW Trained Senior Technician I have used, told me that he could tell if the Throttle Valves needed balancing by the feel of the Throttle response.
(My 2010 Model didn't have the Recall).
Re: Stalling issues
Don't think the bike would show a fault code but I don't understand why they cant check it out for any recall history. It costs them nothing and takes all of 60 seconds to do. I assume you are dealing with a BMW dealer. You could always take DaygloDavid's advice and have a look.
Re: Stalling issues
Hi Slowvet, are you able to remove the cover and look at that Cam Sensor trigger in position on the Camshaft Sprocket, as shown in DaygloDavids photo. Or perhaps print it off for your Dealer to do and check for you ?,
Hope you can get it sorted .
