I just got the first 1000miles on my new 2015LC. One of the things I normally do on a new bike is adjust the angle/tilt/distance of the handlebar to my liking.
I notice my arms are not quiet at the right angle, and they tire more easily than I like. So I am looking at the steering setup and come away confused....
Can you actually change this?
Frank
What kind of adjustment can you make to the handlebar?
Re: What kind of adjustment can you make to the handlebar?
Unfortunately not. The bars are not adjustable.
I can however recommend the Ilium bar risers, which also gives good forward and backward adjustment.
- Spencert231
Hi check out the thread on Handle Bar Riser http://www.iliumworks.com/BMW_Motorcycl ... 00&pID=103
They ain't pretty that's for sure, but comfort is probably more important. As you have only done 1000 miles I'd give it a bit to see if you adapt to the bike.
That's what I will be doing. Most likely getting a bigger windshield though...RTman10 wrote: They ain't pretty that's for sure, but comfort is probably more important. As you have only done 1000 miles I'd give it a bit to see if you adapt to the bike.
Frank
