Anyone have any good sources like beemerboneyard for used OEM parts?
Will be trying the final brake bleed before taking it in to likely get the sad news that the ABS servo module is toast.
Through some additional googling found that it appears that while several years/configurations use the same part number the operation may be different based upon specifics of the bike.
So I'll be in the market for an ABS Module that's specific to 2005 R1200RT
Module Master can rebuild but says that they're waiting on parts and have a couple months lead-time.
Dave
Used OEM parts
- Been liked: 480 times
Re: Used OEM parts
MotorWorks do Used Parts, https://www.motorworks.co.uk/vlive/Shop ... 0_35_HA_70.
Re: Used OEM parts
The servo unit was only used for 2 years. If you feed your chassis No Into real OEM it should come up with the correct one. That's the only way a dealer has to obtain a replacement so it should work for you.
I have seen lots of bits come out of Motorworks/Motobins. Best of luck.
