Details on the right hand fairing pocket with the audio system
JayBro
Post by JayBro »
Hello,
Can anyone help with details on the right fairing pocket if you get the audio system on a 2015 RT please?  Do you know why it is not available if you don't order the audio system?
Could it be installed onto a bike without the audio system? I'm not keen on a tank bag so I'm wondering if I could go without the £1000 audio system but still get some extra storage up front.
Re: Details on the right hand fairing pocket with the audio system
Looks like you can.  Go to Real OEM  and work you way through to the section Frame and Mounting Parts.  you will find a diagram and part numbers for both left and right (as you sit in the bike) compartments
Bet that's not cheap!!
fmantek
Post by fmantek »
Also, take note that you can barely fit an iPhone in there, this is not a tank bag replacement,,,,
Frank
Sent from my iPad using Tapatalk HD
JayBro
Post by JayBro »
Thanks for the replies.  I did find the link to realoem in another post and found it very informative.
I know it isn't a tank bag but I was thinking the 2 pockets might hold some change, phone and wallet, maybe a cloth, and take up less room than a tank bag. I don't think 1 pocket will hold a wallet and phone.
I then started wondering why it is only available with the audio system...
wayneosdias
Post by wayneosdias »
fmantek wrote: Also, take note that you can barely fit an iPhone in there, this is not a tank bag replacement,,,,
Frank
+1 and the ridiculously large dongle they give you for usb charger takes away a lot of the pocket volume and nearly impossible to use w a usb cable/phone while closed
steve.sharkey
Post by steve.sharkey »
Don't need much space for a wallet once you've bought the bike ;o)
