at the side of the passengers hip area there is blank plastic cap, presumably so you can fit an extra elec power out let.
Does anyone know of the part number or equivalent in other make to use this hole without drilling it bigger.
Aux plug
- Been liked: 468 times
Re: Aux plug
Is this what you are looking for, http://www.realoem.com/bmw/enUS/showpar ... Id=61_3041
Re: Aux plug
It could well be, but where in the uk do i get it from….BMW only stock expensive bits for profit
Re: Aux plug
The Part No. 61347694306 (Plug-in socket), cross-references with these other BMW Models,Hodge wrote:Where in the UK do i get it from.
http://www.realoem.com/bmw/enUS/part?id ... 1347694306,
therefore, the "Used - Auxiliary power socket 08/2006 on | ELE94306" from Motorworks should do the job,
https://www.motorworks.co.uk/vlive/Shop ... 0_35_IA_90.
What year is your RT.
Re: Aux plug
The prices shown on Real OEM do not reflect the prices in UK. Think you will get the complete plug including the waterproof cover for a bit over £20.00. Depending on what model you have the wires are already there. There are no aftermarket ones. The hole is the correct size.
Re: Aux plug
Yep, £23.30 from your local BMW Dealer or £10 Used from Motorworks plus P&P, (08/2006 on).RTman10 wrote:The prices shown on Real OEM do not reflect the prices in UK. Think you will get the complete plug including the waterproof cover for a bit over £20.00.
