alarm system
turdboman
alarm system
Post by turdboman »
Looking for input about an alarm for 2016 rt ,the kind with remote . my bike does not have keyless . something for when it's out side a motel on a trip !
Been liked: 36 times
Re: alarm system
If you don't have the factory fitted one, have you considered an alarmed disc lock. Abcus do a very good one
blokeonthemove
Re: alarm system
Post by blokeonthemove »
If your bike has central locking it may be that it's part of the comfort package which has the alarm also, have you looked for it, a long press on the lock button usually activates it.
Re: alarm system
If you have TPM you also have an alarm as it's the same unit.
turdboman
Re: alarm system
Post by turdboman »
don't have central locking or tpm whatever  that is
Re: alarm system
turdboman wrote: don't have central locking or tpm whatever  that is
Tyre Pressue Monitor.  Can't work out the spec on your bike.  You have the audio system but no central locking.
turdboman
Re: alarm system
Post by turdboman »
i have tpm ,audio and a key lock fork and ignition ,i think i have every thing but key less
Re: alarm system
Have you got a fod as well as a key.
turdboman
Re: alarm system
Post by turdboman »
RTman10 wrote: Have you got a fod as well as a key.
NO !!
Re: alarm system
In that case you don't have an alarm.
Cleverbee
Re: alarm system
Post by Cleverbee »
I fitted a HAWK remote alarm a couple of years ago to my LT, the type that isn't defeated by shorting out an indicator, along with motion sensor.  I can't promise if it will match the cambus system of the RT but if it does, get one!!!
There must be one out there somewhere...
Re: alarm system
I would think that trying to install an aftermarket alarm into the Limbus system on an LC will be a very dodgy thing to do.  The factory fitted one is available for fitting by a dealer.
turdboman
Re: alarm system
Post by turdboman »
RTman10 wrote: In that case you don't have an alarm.
I know I don't have an alarm,I'm looking for info on adding one . not the one from bmw it's $289 plus $100-$150 to get installed and that's without a remote,it has to be installed by bmw .
