Gap under the seat?
Gap under the seat?
Hi, I am sure the topic has already been discussed so apologies in advance. Have put my heated regular seat on its high setting and have noticed that there is now a (narrow but disturbing) gap between the lower side edge of the seat and the bodywork. Thought I made a mistake in putting the seat back and tried to reinstall it twice to no avail. Is it me being thick and ham fisted or is it BMW's design a little flawed? Ciao! Massimo
Re: Gap under the seat?
Orso62 What year is the bike??
Are you sure its a regular seat and not a low one?? If you put a low seat in the high setting it gives you a gap or at least it does on the pre watercooled machines
- Been liked: 239 times
Is this what the seat/bodywork looks like in the Low & High positions.Orso62 wrote:Have put my heated regular seat on its high setting and have noticed that there is now a (narrow but disturbing) gap between the lower side edge of the seat and the bodywork.
This is why I don't put the Standard Seat in the High position on my 2012 RT, it "looks a bit naff".step2534 wrote:If you put a low seat in the high setting it gives you a gap or at least it does on the pre watercooled machines.
Yes. It looks like that. Thank you. Seat will go back to the low position but I must say that BMW could have designed it a little better!
- Been liked: 14 times
Hi David,This is why I don't put the Standard Seat in the High position on my 2012 RT, it "looks a bit naff".
I also think it looks "a bit naff". I was thinking of getting the high seat and putting in the low position. How did that work out for you?
Sorry for any confusion, a 2012 RT (which I have) has a Standard & Low Seat option only, whereas the LC has 3 options, High, Standard & Low.beemerboy9 wrote:I was thinking of getting the high seat and putting in the low position. How did that work out for you?
I don't see how, with the panel obviously always in the same position it would be possible not to see more of it if you raise the seat. There isn't really a gap just more of the insert showing. Quite a neat solution for a seat that allows you to put it in 3 different positions.
3 positions ? There's only 2 High and Low on mine RTman10 wrote: Quite a neat solution for a seat that allows you to put it in 3 different positions.
Same frame different seats adds up to at least 3 if not more if you see what I mean. Most bikes it's as it is.
What Year is your Bike & which Seat do you currently have.beemerboy9 wrote:I was thinking of getting the high seat and putting in the low position.
I don't see what the problem is. It is a functional adjustment. It works. Having versatility often requires trade offs. Every time you think about it, get on the bike and twist the throttle. I bet you will forget all about it in no time.
Sent from my SM-T310 using Tapatalk
