Hi
I googled this fault and a few things came back that the ABS can be RESET. I cant find out how to do this on my 2008.
Would anyone have a view if this is worth a go as the dealer when I rang said I will be up for a new ABS board!!
Was a mention of don't start the bike with brakes on as this can wreck the ABS ( I did this as I started on a hill - what else can you do)
I would like tot ry & reset the ABS Warning fault BEFORE going to a replace the ABS board!
How does one do it for the 2008?
thanks Geoff
ABS Warning Light on my 2008 RT SE
- Been liked: 252 times
Re: ABS Warning Light on my 2008 RT SE
Have you seen this thread on BMWLT, http://www.bmwlt.com/forums/rt-series/3 ... ilure.html,
it doesn't mention resetting the ABS but gives some possible causes of why the ABS light might be on.
When does the ABS Warning Light illuminate,
a) it happens before you start the engine,
b) it fails when you start the engine,
c) it fails when you ride away.
Is the ABS Light flashing or staying on.
A thread from BMWSportTouring, http://bmwsporttouring.com/ubbthreads/u ... 075&page=1,
"Is there a way to reset the ABS system?-- Not really, you can try disconnecting the battery for about 10 minutes but that is about it."
Bit rich for a dealer to tell you it's the main ABS unit without seeing the bike. Might be no more than one or the sensors or its cable. Ring another dealer .
- bieffe
- Bike Model and Year: bmw 1200 rt 2007
- Been liked: 1 time
I had similar problem, needed to fix the ABS module, now 1000 km OK.surferseagull wrote: Hi
thanks Geoff
