No sound from Navigator V on R1200RT 2015
RT-man
Post by RT-man »
Hi there;
Do I have to perform any setup to get the sound / guidance from the Navigator V through the speakers?
pbsrides
Re: No sound from Navigator V on R1200RT 2015
Post by pbsrides »
Sometimes there's a glitch. Mute, then unmute the Nav5. That should make the sound work.
And also make sure the audio unit the Nav has BT disabled. If you can get the radio to play through the speakers so will the Nav
RT-man
Post by RT-man »
Ok, thanks for the tips.
Unfortunately still no go. I will get my dealer to check it out when the bike soon in due for the Run-in sevice,
RT-man wrote: Ok, thanks for the tips.
RTman10 and RT-man...
are you guys related - or are you the same person posting both sides of a discussion???
I think we should be told...
beemerboy9
Been liked: 16 times
Post by beemerboy9 »
RT-man wrote: Hi there;
I had this problem on Sunday. I removed the Satnav from the mount and remounted it (I may have even got some spurious message about a car mount from the Nav). Everything working again.
STeinar
Post by STeinar »
Yes, and remember that the radio will have to be on and that the volume has to be up. If you don't want to listen to the radio - set the input selector to USB or something, but let the audio unit powered on and volume up.
And sometimes needed - on the GPS when mounted - mute the gps - then unmute again.
It's not unusual for someone of my vintage to get a little confused now and again. But answering my own questions !!
I don't know - I spend a lot of time asking myself questions...
