Hi Guys,
after much reading about the various options for fitting a pair of additional front spotlights / daylight running lights to my 2015 R1200RT LC, I decided to get the OEM version.
I have ordered them from my dealer to fit myself but I reading differing information on whether I will then have to get the software changed the dealers to activate them?
The items on order are a pair of OEM spotlights or as they are listed on the invoice 'headlights' as per the following list;
C63.17.8.532.147 Headlight x2
C63.17.7.721.318 Bracket x2
C06.32.7.657.949 Screw x4
C07.12.9.907.398 Fillister x2
C07.12.9.905.826 Hex Nut x2
C63.17.8.541.630 Holder x1
C63.17.8.541.631 Bracket x1
C07.12.9.907.381 Fillister x2
C61.31.8.533.473 Switch x1
The final item (Switch) is actually the switch on the handlebars and the full loom that plugs into the back of each light.
Has anyone else fitted the above items themselves, (specifically the switch and loom assembly) and if so are there any instructions on routing it please?
Mark.
Fitting OEM (DRL) Spotlights to 2015 R1200RT LC ?
Re: Fitting OEM (DRL) Spotlights to 2015 R1200RT LC ?
Looks right, and yes - you need to visit your dealer to "enable" the controller inside the switch.
This so the computer onboard your bike can "talk" to the small but still there - computer inside the switch-unit.
STeinar wrote: Looks right, and yes - you need to visit your dealer to "enable" the controller inside the switch.
Thanks STeinar, have you done this yourself? is the cable routing pretty straight forward?
Yes - no problems, but be careful when routing the cable to the right light - so it's not in interfering with anything.
Installing LED auxiliary headlightsk_new.pdf
Brilliant, Thanks for the link thats exactly what I was looking for...
Just in case the dealer hasn't told you, are you aware that if you have the Headlight Pro fitted the lights will only work when you select dip beam.
Mine must have been connected wrong then, because mine still work on full beam and I have headlight pro fitted!
I ride a lot a night so I'm not imagining it
And I've just been out to my garage to check and I am not imagining it, they stay on with full beam 8)
Do they still work when on the Angel Eyes are on?Casbar wrote: And I've just been out to my garage to check and I am not imagining it, they stay on with full beam 8)
What they do is if you are on DRL they won't work. You need the main headlights on and this dulls the Angle Eyes. So you ride with very bright angle eyes or main headlights and spots.
RTman10 wrote: What they do is if you are on DRL they won't work. You need the main headlights on and this dulls the Angle Eyes. So you ride with very bright angle eyes or main headlights and spots.
Yes that is what is happening, the Angel eyes dim and main headlight on. But they stay on with dipped and main beam.
RTman10 wrote: Just in case the dealer hasn't told you, are you aware that if you have the Headlight Pro fitted the lights will only work when you select dip beam.
They didn't mention it but I don't have it anyway :-) thanks for the heads up though.
correct...
