Front disc bolt torque?
Has liked: 80 times
Been liked: 87 times
Post by Sullivj »
My Haynes hasn't yet arrived.
Could someone please tell me what the front disc bolt torque should be?
Thanks.
MacJ
Re: Front disc bolt torque?
Post by MacJ »
The manual states 38 NM
Has liked: 80 times
Post by Sullivj »
Brilliant - thank you very much. I was sitting here, looking at the wheel, hoping that someone would reply - much appreciated - thanks.
The Haynes Manual for the R1200 dohc Twins 2010 to 2012 gives the following Torque setting.
Front brake disc bolts 19 Nm.
Has liked: 80 times
Post by Sullivj »
DaygloDavid wrote: The Haynes Manual for the R1200 dohc Twins 2010 to 2012 gives the following Torque setting.
Thanks David. That explains why I couldn't get passed 25nm without shearing 2 torx bits!
"Tight's tight - too tight is knackered"!
guest3074
Post by guest3074 »
David is correct with the torque settings  :) MacJ quoted the settings for caliper mounting bolts  :o
The front brake caliper mounting bolts are 30 Nm, in both the Haynes Manual & BMW Rider's Manual.
guest3074
Post by guest3074 »
DaygloDavid wrote: The front brake caliper mounting bolts are 30 Nm, in both the Haynes Manual & BMW Rider's Manual.
Not if you're looking at the manual for water cooled  :silence:
DaygloDavid wrote:The Haynes Manual for the R1200 dohc Twins 2010 to 2012 gives the following Torque setting.
guest3074
Post by guest3074 »
Yes I know, I was referring to the small difference in what I quoted as it's slightly different for the water cooled RT's which coincidently is the same value that MacJ quoted.  ::)
Sullivj wrote:Could someone please tell me what the front disc bolt torque should be?
What year/model is the bike?
cdnrtowner
Post by cdnrtowner »
Hey Gents,
I have just checked the front discs and they move ever so slightly. I checked the back disc and it does not move at all. Has anyone noticed the same slight movement?
Thanks. Cheers, Pat
daverj
Post by daverj »
Different mounting methods fixed floating and semi floating.  The latter help reduce warping by allowing the disc to expand and contract
R1250RT LE
Has liked: 80 times
Post by Sullivj »
Yes, both my front discs (2012) float around slightly.
cdnrtowner
Thanks Dave for clarifying the discs tightness issue. After writing my question, I realized the floating/heat dispersion aspects. Notwithstanding my realization, I appreciate you taking the time to answer my query. Cheers Pat
