2008 r1200rt seat
Hodge
2008 r1200rt seat
Post by Hodge »
Needs a pointer here if you please.
When i put the seat in the high position it locates OK but after a few miles it seems to move  so that the wings if you like that go under the tank (forward) flick up and rub on the tank.  It doesn't move but it doesn't look right,  Also when i remove it then it feels wedged in as opposed to located.
Is this normal?
Re: 2008 r1200rt seat
If you mean the adjustable bar with the rubber bungs on the end,IT  should be held in place with big thick rubber bands.  Look at Real,OEM. That are called tension straps.
falconmick
Post by falconmick »
Where are you located? Somebody may be able to let you have a look at theirs.
Or take the photo with seat off and the bar where you put it before it moves.  Are you sure the location cups on the seat aren't damaged
Hodge
Post by Hodge »
I,m in southampton
Been liked: 249 times
If nothing is missing or broken & the seat is fitted correctly, it shouldn't move in either the high or low positions.
FRONT SEAT-VERTICAL SEAT ADJUSTER - http://www.realoem.com/bmw/enUS/showpar ... Id=52_3213
Bench seat - http://www.realoem.com/bmw/enUS/showpar ... Id=52_3214
Hodge
Post by Hodge »
I have checked and rechecked and can't see how it could move.  it locates perfectly, the seat pan is not cracked or broken and when i try to lift the wings of the seat they won't move.  And yet when i ride it and get home.  I will take a photo when i next get back to show
