2008rt
Hodge
2008rt
Post by Hodge »
Ok,  Valves adjusted, new air filter and plugs, Gearbox oil. all done.
Carbtune arrived and set up and 1st try reveals right hand cyl is below left at tick over.
NB  Throttle body cable has free play on right but none on left!
So do i adjust the left to come down or the right to come up on the carbtune grad scale.
PS If spellcheck calls it a carbine once more then i may throttle somebodys carb
Re: 2008rt
Hodge wrote:So do i adjust the left to come down or the right to come up on the carbtune grad scale.
What vacuums are showing on each cylinder, the Haynes Manual gives a spec. of 25 mbar (max) at idle.
