Fogging on computer display
Richmac
Post by Richmac »
Anyone else had fogging/misting on the inside of the computer display.  First sign of it today.
Re: Fogging on computer display
If it's the LC yes.  Only does it in temperatures below 10C and goes away on a long trip.  Complete unit was changed when it first happened but the replacement still does it now and again but only in th lower window area.  It goes away about 15 minutes after switch off. My 1600 did the same thing.
Richmac
Post by Richmac »
Cheers, thanks for that. No so bad and as you say gone after parking up for a while. Keep you posted if it gets worse.
futterweasel
Post by futterweasel »
I had the same problem on my rt after washing it, informed my dealer who replaced the seal under warranty, haven't had the problem since.
Richmac
Post by Richmac »
Thanks. I'll keep that in mind when cleaning.
