After market Horns
After market Horns
I have a 2016 RT and would like to install a much louder horn. Has anyone installed a good loud horn yet and how hard was installation? did you install in stock location?
- Has liked: 80 times
- Been liked: 87 times
Re: After market Horns
I fitted a Stebel Naulitus to my CB500, and will do the same to my newly acquired RT. Details of the CB500 fit ment are here:
http://www.cb500club.net/t2248-fitting- ... cb500-pics
I too fitted a Nautilus horn using the recommended wiring kit which includes a relay. Instructions fairly easy to follow. Tricky part is getting sufficient access to remove the old horn and fitting new bracket. The Nautilus is very much louder. I feel safer knowing that if I have to use the horn other road users will definitely hear me!!
I fitted the low tone horn off a 5 series BMW, cost me £30 I think. Direct swap, plugs straight into the existing contacts and uses the same mounting points. Quite loud, much better than stock.
Thanks for the replies everyone! Casbar, does it matter what year 5 series is? I have read a lot of negative reviews on the of the Nautilus, mainly that it doesn't work at all or quits shortly after installing. Webbike world did a review of it also with negative report. I'm leaning toward the 5 series idea or the sound bomb. Thanks again for the ideas.
One issue with the Nautilus, is that you need to install it with no more than a 15 degree angle off vertical. I wonder how many people don't properly achieve this
I've been running mine for a number of years in all weathers, and never had a problem with it.
Banzib wrote: Thanks for the replies everyone! Casbar, does it matter what year 5 series is? I have read a lot of negative reviews on the of the Nautilus, mainly that it doesn't work at all or quits shortly after installing. Webbike world did a review of it also with negative report. I'm leaning toward the 5 series idea or the sound bomb. Thanks again for the ideas.
Yes it does, let me get the details for you, will be back later
Here you go, bought mine from a local dealer, but there are ones on eBay.
[size=14px]E39 5 [/size][size=14px]Series[/size][size=14px] low tone[/size][size=14px][size=14px]Part# 61-33-8-381-271 Horn Low Pitch[/size]
[size=14px]
[/size]
[size=14px]Here is the threat about it - [/size]
[size=14px]
[/size]
http://www.bmwlt.com/forums/rt-series/1 ... horns.html
[size=14px]
[/size]
[size=14px]
[/size]
