Controller sub menu
scunny1
Controller sub menu
Post by scunny1 »
Has anyone any trouble in selecting sub menu from controller? Mine does not seem to work pushing to the right or left, am I doing something amiss or something to bring up at next service due next month?
scunny1  R1200RT LE 2015
Re: Controller sub menu
If you click on the Trip/Favourite switch can you scroll through the Info list.  If you can are you saying that if you then push the wheel to the right it does not set that item on the dash. A push to the left should exit the Menue. And also presumably you are unable to set your ESA etc.
If you can't you are due a new wheel.
