Tom tom mount
exportman
Has liked: 7 times
Been liked: 43 times
Tom tom mount
Post by exportman »
Hi
As I already had a tomtom and have been using them for years I was not going to fork out for a Garmin device.
However I did want to put the tomtom in the same place.
First thing I did was set about removing the Garmin mount.
Next was work out how to mount the Tomtom.  My solution was simple    I purchased a Hasp and Staple from a diy shop
This is mounted vertically  just drilled the  mounting point  and used nuts and bolts to hold it in place.  Then once I had the location sorted  I drilled the hasp to accept the tomtom mount and secured that to it.
Next I needed a way to make it stay in place    Simple solution a couple of neodymium magnets  taken from an old server hard drive
Power is via a fuse box in behind the right hand speaker cover,  This is fed from the battery through a fused relay . Switch feed is connected to the aux power socket.  This fuse box is also powering my dash-cam set up and some LED auxiliary marker lights used when filtering  just to make me a little more noticeable
Finally just to tidy it up a bit  a piece of Carbon effect plastic  to cover the holes and cut outs behind the garmin mount.
Just need to tidy up the wiring a bit  when I get five mins to spare.
Re: Tom tom mount
Very ingenious I have to admit.
Not sure what it'll do for the resale value of the bike though, assuming it came with satnav prep and connectivity to the wonder wheel.
notnot
Re: Tom tom mount
Who used to say Not a lot.  But it's only one of a few alterations the bike Has already had.  But it's his bike.
exportman
Has liked: 7 times
Re: Tom tom mount
Post by exportman »
Hi
I can restore the Garmin mount and it will cover the extra holes I made.  It just plugs in behind the fairing.
All the  wires can be removed  and the  Pannier lids can be returned to the full size ones.
Everything I have changed  can be changed back with very little evidence
So should not be an issue.
Has liked: 52 times
Been liked: 65 times
Re: Tom tom mount
Post by Sullivj »
Very innovative. Thanks for sharing.
Is it a TOMTOM rider, running on 12v, or a car TOMTOM running on 5v. If the latter, how did you deal with the power change?
exportman
Has liked: 7 times
Re: Tom tom mount
Post by exportman »
The tomtom rider motorcycle dock requires a 12v feed  it provides the step down to 5v required by the tomtom unit.
Re: Tom tom mount
exportman wrote: Hi
In that case, I take my hat off to you - very clever adaptation.
:clap: :clap:
exportman
Has liked: 7 times
Re: Tom tom mount
Post by exportman »
Sullivj wrote: Very innovative. Thanks for sharing.
Assuming you have not got the audio kit I would either power this from a cig socket  adaptor  or add a USB adaptor  from the AUX socket on the right hand side.  If you have not got the audio kit then behind the speaker covers is a lot of space you can use to keep everything out of sight, neat and tidy.
Re: Tom tom mount
Joining things to the auxiliary socket can stop it working as a battery charger attachment as they detect a drain and switch off.
BMW ones will.show you an error.
exportman
Has liked: 7 times
Re: Tom tom mount
Post by exportman »
RTman10 wrote: Joining things to the auxiliary socket can stop it working as a battery charger attachment as they detect a drain and switch off.
I have it just serving a relay  that then provides the power direct from the battery for everything else.
Just out of interest  my mate has a GS  he has the special charger  but it does not work very well the bike would not start this morning
Its two years old and the battery is dead.
Re: Tom tom mount
The charger would have shown him the battery voltage so he should have been aware there was a problem.  The GS has an AGM battery.  If they are allowed to go flat it normally kills them.  I'm sure he would have complained to his dealer if it was only 2 years old.
