Garmin express 4.3.0.0 update now available
stayingupright
Post by stayingupright »
Update now available
Last edited by stayingupright on Fri Nov 11, 2016 11:02 am, edited 1 time in total.
Been liked: 280 times
Re: Garmin express 4.2.0.0 update now available
Is it a Garmin Express or map update.
Nothing shows if you just open it with nothing connected.  probably update itself if you plug in your nav to do an update.
stayingupright
I did a map update from Garmin express last week but could not tell you how old it was.
stayingupright
Re: Garmin express 4.3.0.0 update now available
Garmin express can be updated without anything plugged into the computer
How.  Nothing shows.
stayingupright
RTman10 wrote: How.  Nothing shows.
Go to the settings menu at the top of the express screen and drop down to "about"
It's in there
Found a map update from 2017.10 to 2017.20, have started installing on both Computer and Device.
Looks like it's both a Garmin Express & map update.
stayingupright
That was the one I got last week.
I should check this more often really
Last edited by stayingupright on Fri Nov 11, 2016 11:03 am, edited 1 time in total.
Found it but shows I already had 4.2.0.0.  It offered 4.3.0.0 which has failed twice so I've given up..
stayingupright
Damn!
Since posting about this the update has been updated
I'm now on 4.3.0.0
What do Garmin Express updates do?
DaygloDavid wrote: What do Garmin Express updates do?
whatever it is, I bet they do it fast....
How long does the Garmin Express update take?
Currently still downloading files for the map update, now up to 4 hours 20 minutes.
guest3074
Post by guest3074 »
DaygloDavid wrote: How long does the Garmin Express update take?
Downloaded and installed in around 2mins  :)
