LED headlight for an RT?
stayingupright
Post by stayingupright »
Has anyone tried a LED headlight bulb to replace the normal one in the RT?
The pictures in the link look quite impressive on first glance.
http://www.ukgser.com/forums/showthread.php/438976-2013-led-upgrade
Has liked: 80 times
Been liked: 87 times
Re: LED headlight for an RT?
Post by Sullivj »
One of the comments suggest they don't last long.
stayingupright
Yeah, I noticed that ... Although that did look like it was directed at cheap eBay lights from China.
The light output does look impressive though.
Only trouble it is an absolute minefield as to what to get so was hoping that someone had already gone down this route.
guest3074
Post by guest3074 »
There are a couple of threads if you search, like this one /viewtopic.php?t=9
They say 35W.  As the limbus expects there to be 55W you would probably end up with a warning light on all the time.
stevegold6
Post by stevegold6 »
RTman10 wrote: They say 35W.  As the limbus expects there to be 55W you would probably end up with a warning light on all the time.
This is the reason I chose the 35watt.
As for how long they will last...I will let you know..
Cheers
Steve
