Headlight aim - adjustment
mattye
Post by mattye »
Hi all,
Does anyone know if you can raise the headlight aim in addition to the lever under the headlight itself?
When I bought my RT the headlight beam seemed really high and even with the adjuster right down seemed a bit high. Then i had a run in quite literally with a pigeon and now its really low. Is there any adjustment for the headlight unit itself?
Thanks all
Re: Headlight aim - adjustment
If it moved when you had your incident it's a pigeon something has broken. Can you feel movement in the headlight unit.
mattye
Post by mattye »
Hi RT Man
can't feel any movement at all which is a bit odd.
Been liked: 249 times
What year is the RT, perhaps the pigeon has just nudged some adjustment that was seized.
mattye
Post by mattye »
its a 2104 lc
What loading is on the bike, are the suspension & headlight adjustment set up accordingly.
mattye
Post by mattye »
Its only me riding with nothing in the panniers. I have the suspension set onto road so should all be ok.
Is there a measurement for the headlight aim. i.e. the bike a set distance from a wall and the headlight aim should be 3ft up or something like that?
mattye wrote:Is there a measurement for the headlight aim. i.e. the bike a set distance from a wall and the headlight aim should be 3ft up or something like that?
Do you know a friendly MOT testing station, if so, ask if they will check the headlight aim for you.
mattye wrote:Its only me riding with nothing in the panniers. I have the suspension set onto road so should all be ok.
My understanding is that the riding mode (road) only sets the damping & not the ride height for the loading on the bike, is the ESA set for one-up.
Road is an engine mode, nothing to do with suspension.  Other settings being Rain and Dynamic.
Looks like in "Road", the damping is "Normal", the "Load setting" needs to be selected by the rider, while the bike is stationary.
mattye wrote:The headlight aim, lever under the headlight.
DaygloDavid wrote: Looks like in "Road", the damping is "Normal", the "Load setting" needs to be selected by the rider, while the bike is stationary.
On the LC the ESA setting will automatically change the Mode setting as shown. You can however reset to whatever you want. Makes no difference to your headlight as the Dynamic ESA will attempt to keep the bike level no matter what the setting is.
The manual "Load setting" will adjust the headlight aim.
"Headlight beam throw is generally kept constant when spring preload is adjusted to suit load. Spring preload adjustment might not suffice only if the motorcycle is very heavily loaded. Under these circumstances, headlight beam throw has to be adjusted to suit the weight carried by the motorcycle."
