Aftermarket batteries, ah rating, gel vs. agm
I'm looking for an aftermarket battery for my 2011 R1200rt. I found a Bikemaster that fits but the AH is 16 or 17 instead of 19 as per manual specs. Will this be a problem? Any suggestions re Gel vs. AGM or manufacturers/retailers? Any help will be greatly appreciated. Thanks. Roger.
- Been liked: 243 times
Re: Aftermarket batteries, ah rating, gel vs. agm
Which one, http://online.fliphtml5.com/lxnd/cjbv/#p=22, they offer four for the RT, http://bikemaster.com/catalogsearch/result/?q=51913rogervk wrote:I found a Bikemaster that fits.
Highly recommend a Motobatt.
I think the part no is MB51814.
AGM 22AH
Cheers.
AGM 22AH
Cheers.
BikeMaster do a conventional battery with a capacity of 19, http://bikemaster.com/conventional-battery-6730.htmlrogervk wrote:I found a Bikemaster that fits but the AH is 16 or 17 instead of 19 as per manual specs.
Bikemaster seem to be US based only. Their gel batteries cost more than an OEM one. You wouldn't believe the damage a lead acid battery can do if it spills.
The BikeMaster TruGel Battery costs $167.95, http://bikemaster.com/trugel-battery-5142.html
The BMW OEM one costs $190.61, http://www.sierrabmwonline.com/product_ ... 19as-p-371
$168 is £131. Same price just about as an OEM. Do we know where he is. I assumed UK.
My guess is the US, "BikeMaster is distributed exclusively in North America by Tucker Rocky Distribution".
The BikeMaster battery has a 2 year warranty, https://www.youtube.com/watch?v=fZ4u1LAY0_0
I wasn't sure as his first post was all about an Optimate and he types (English)
Optimate are available in the US.
One of US will be correct, the suspense is killing me.
Now if Steinar made it impossible to register without adding your location life would be much easier
No, that wouldn't be half as much fun.
Both Rodger's posts were made at 03:00.
The forum clock is set GMT + 1 hour.
Now back to the batteries, this thread on replacement batteries may be of interest, https://1200rt.com/viewtopic.php?t=5
