where can i buy a canbus socket?
i want to make one of these (see pic), as i think £18 is a rip off for a bit of moulded plastic and two wires
so....any ideas where i can purchase a canbus socket?
Re: where can i buy a canbus socket?
The BMW one has 3 cables and I would have thought costs less. Avsilsble from any dealer
- Been liked: 410 times
Would item no. 09 be what you are looking for, http://www.realoem.com/bmw/enUS/showpar ... Id=61_2484
yes, item 9. but they are £21
nothing's ever cheap with BMW is it?
£8.56 from Rainbow BMW, http://www.rainbowbmw.com/BMWETK/Produc ... 012950.phpds99 wrote:yes, item 9. but they are £21
Where are they £21?
i think i will just jam paperclips into the existing canbus plug and gaffer tape it up
ds99 wrote:Any ideas where I can purchase a canbus socket?
Are you looking for a socket (female) or plug (male) connector.ds99 wrote:I think I will just jam paperclips into the existing canbus plug.
What are you connecting. Nippy N want £20.50 with postage. They call,it a horn connection.
I'm confused, what are you connecting the horn to.ds99 wrote:I am fitting a new horn (that has spade connectors).
i have removed the BMW horn, this is connected via a canbus plug and socket.
i wish to install a new horn, but it has spade connectors (ie not canbus)
this is what i have at the moment
and i want to install this instead
What's left on the bike, a socket or a plug.ds99 wrote:I have removed the BMW horn, this is connected via a canbus plug and socket.
If you would like a cheap option, cut the BMW socket/plug off & fit some female spade connectors.
Just leave some wire on the BMW socket/plug in order that it can be replaced at a later date if necessary.
