Right side Glove Box?
fastbmw
Post by fastbmw »
I have a 2016 r1200rt which includes the left side Glove Box.  Question - is there a Glove Box for the Right side?  It sure looks like there is space.
I've googled this, but turned up nothing.  Appreciate any insight :)
2016 R1200RT
Been liked: 280 times
Re: Right side Glove Box?
guest3075
Post by guest3075 »
46 63 8 544 950 SEAL FLAP, RIGHT 1  £39.20
46 63 8 544 958. STORAGE BIN LOWER SECTION, RIGHT 1  £83.51
46 63 8 544 946 SEAL FOR STORAGE BIN, RIGHT 1 £19.31
46 63 8 532 314 SELF-LOCKING PLUG NUT - M5. 1  £1.25
46 63 8 534 872 SPRING. 2  £6.50 (£3.25 each)
46 63 8 549 852 FOAM INSERT, RIGHT. 1  £3.71
46 63 8 521 654 BODY SCREW WITH SHOULDER - M5X17,5MM 2  £2.78 (£1.39 each)
guest3075
Post by guest3075 »
That photo is mine!  :-)
Note that if you do get the box, it has a large oval hole to let the BMW USB cable in, which normally has a grommet.
Other than that it's 10mins to swap them over, and you need a key and central locking actuator if you have CL.
fastbmw
Post by fastbmw »
Thanks!
2016 R1200RT
B787MECH
Bike Model and Year: 2016 LC
Post by B787MECH »
Hi, I'm interested in this. One query, how does the usb cable connect to bike? Is there a plug socket on the bike in that area? Just got my 2017 RT so still finding my way around. Cheers.
No way to connect it unless you have the audio unit in which case you already have the locker and the cable.
