Foot brake lever issue
Hi when I put my foot on the brake lever of my (recently purchased/rarely ridden) 2009 R1200RT I find I step on the 'triangle' above the lever/pedal (see photo) then as I apply more pressure my foot slips down onto the lever. Bit off putting until I realised what was going on. I note new RTs do not have this type of brake lever. Any easy cheap solution to this issue?
- Has liked: 36 times
- Been liked: 52 times
Re: Foot brake lever issue
Hi, I put a 'Brake pedal enlarger' on mine, Not cheap for what it is but made it feel better after coming from bikes with bigger brake pedals.
www.nippynormans.com/wunderlich/r1200rt-to-09/wunderlich-brake-pedal-enlarger-r1200rt-to-2013
simbo wrote: Hi, I put a 'Brake pedal enlarger' on mine, Not cheap for what it is but made it feel better after coming from bikes with bigger brake pedals.
I was going to make the same suggestion. Of course, you could always trade it in for an LC model...
Sullivj wrote: I too put an extender on mine, albeit the cheaper one from EBay.
You get a free picture with the Wunderlich one though
Thanks for the response and Hi Simbo do you mind putting that link back up again as when I try to follow it I get an Error 404.
OK guys I figured it out! Cost of STG£29 for the Brake Pedal Enlarger. Thanks again.
Sullivj wrote: The Ebay one was only £10.50. Can it really be 3 times as good?
I wouldn't have thought it was any better at all, I'd have got the £10.50 one had I know about it
- k9doc
- Bike Model and Year: Suzuki VStrom AK7GT
Here's one I made earlier.
Ordered an extension for brake and gear levers from Sportouring, one on back order so in the meantime decided to 'knock up' a temporary stand in.
An off cut of rigid water pipe, some offcut rubber sheet (could have used gorilla tape) and a rubber grommet from Halfords. They work a treat, needn't have bothered with the real thing and cost about 20p for the pair. What's not too like.
Not particularly stylish and not TUV rated but who cares.
Chris
Hi K9doc very impressed with your innovation. I'm not sure I would have the confidence to make and fit something like that on my brake lever. Stay safe out there.
- Sprintgull
Good work K9Doc. All it needs now is a little BMW badge on the end. (That'll start 'em off - you'll see)
- k9doc
As mentioned in a previous post, looking for a cheap Chinese copy of the rounded but can't seem to find one.Sprintgull wrote: Good work K9Doc. All it needs now is a little BMW badge on the end. (That'll start 'em off - you'll see)
Chris
- k9doc
The Wunderlich offering is just a bit of Aluminium tube with a bit of fancy machining. Still needs gluing on to stop it falling off. Being the 'Anniversary Edition' I think the 'blackness is more in keeping than the boring old silvery colour of the proper job. In any event it stops my foot missing the pedal altogether, which has to be an improvement.Frank123 wrote: Hi K9doc very impressed with your innovation. I'm not sure I would have the confidence to make and fit something like that on my brake lever. Stay safe out there.
Chris
STG£29 later (free postage) Wunderlich brake pedal Enlarger received and fitted, job done! See photo. While there is a locking screw fitted a touch of super glue is a good idea so that it doesn't fall off (to be sure, to be sure). Have yet to try it out on the road.
