iPhone to bike?
iPhone to bike?
Is there a way to connect the music on my iPhone to play through the bike speakers via BT?
I have the Nav V
I have the Nav V
Re: iPhone to bike?
unfortunately there is not a way to connect to the bike speakers without hard-wiring, or more specifically, using the data port on the right glove compartment. the only "source" options are Sat, Radio, and Aux. The BT function on the bike is designed to be used with a BT headset (ideally, for BMW, the BMW Communicator, however other brands may work as well) as an output. There is , not yet, a BT option input.
There are , perhaps, some aftermarket wiring solution that may be available, however.
Chris B. https://www.youtube.com/user/kiki231000
Re: iPhone to bike?
Hello.
Connect a bluetooth receiver f.eks Belkin soundstream to the aux and usb in your right hand glovebox. I have and it works fine.
Fosningen.
Fosningen.
- Been liked: 22 times
Re: iPhone to bike?
DBLXX wrote: Is there a way to connect the music on my iPhone to play through the bike speakers via BT?
I have the Nav V
Most folks want to be able to change/skip tracks on the iPhone using the control wheel as well as to keep the phone charged while they travel. Therefore they choose to connect the iPhone via the accessory cable available from BMW.
Re: iPhone to bike?
And I believe from MINI dealers at half the price. Exactly the same cable.
- blokeonthemove
- Been liked: 1 time
Re: iPhone to bike?
Still easier to insert a USB flash drive which will display the file structure , tunes and performers on the dashboard and operate through the wheel.
Re: iPhone to bike?
blokeonthemove wrote: Still easier to insert a USB flash drive which will display the file structure , tunes and performers on the dashboard and operate through the wheel.
I agree. Despite several cables and more than one iPod/iPhone, I never got a more reliable solution than the USB approach...
Re: iPhone to bike?
Well I got the correct cable but it still shows "no usb" when I connect my iPhone SE. Maybe the iPhone SE is not compatible.
Re: iPhone to bike?
Do you have a link for this? Is it something like this?RTman10 wrote: And I believe from MINI dealers at half the price. Exactly the same cable.
http://www.ebay.com/itm/Audio-Interface ... 1961793963
Re: iPhone to bike?
I went for a cheap 'Mini' cable from eBay and an old 4th Gen iPod. Never had a problem with it. If you can't get your phone to talk to the bike then I would be suspecting the cable.Potential new owner.. wrote: Well I got the correct cable but it still shows "no usb" when I connect my iPhone SE. Maybe the iPhone SE is not compatible.
Re: iPhone to bike?
Paggers wrote: I went for a cheap 'Mini' cable from eBay and an old 4th Gen iPod. Never had a problem with it. If you can't get your phone to talk to the bike then I would be suspecting the cable.
Do you have a link for that. The only "cheap" cable I found says it won't work when ios11 comes out. Thanks
Re: iPhone to bike?
IPhone 7 charge & audio cable for BMW mini eBay about £21.50 eBay number 112488410617
