Changing battery.
Changing battery.
2006 RT. Not sure of the age of my battery, looks to have been on the bike a while. Currently fitted is a Varta 19ah 170amp, It has never let me down, yet, but I do keep it on trickle between rides. However it worries me on start up as the cranking speed appears slow,( new to the RT.) A tester shows 12.3 volt. She always fires up after a couple of turns. I have a big run coming up in June and thought to be sure I would change it. Will disconnecting mess with the computer or is this just a case of resetting the time once the new battery is on.
Many thanks.
Many thanks.
- Been liked: 476 times
Re: Changing battery.
The Haynes manual says,mentalrental wrote:Will disconnecting mess with the computer or is this just a case of resetting the time once the new battery is on.
"Disconnecting the battery leads deletes all memorised settings (e.g. throttle position sensor).
Loss of this information could temporarily upset the running of the engine.
Make sure the procedure in Step 11 is carried out before starting the engine.
11 Switch the ignition ON. Fully open and close the throttle a couple of times - this allows the engine control unit to register the throttle butterfly positions via the sensor."
What make of battery are you thinking of getting.mentalrental wrote:Currently fitted is a Varta 19ah 170amp.
- Has liked: 80 times
- Been liked: 87 times
I just checked my battery. It shows 12.6v, but drops to 9.2v on startup. According to this chart, that's a problem.
I may also be looking for a new battery.
Probably this one:
https://www.tayna.co.uk/GEL12-19-Exide- ... P8398.html
That's a good price, the same one from BMW is £155.00Sullivj wrote:I may also be looking for a new battery.
Probably this one:
MDS do this Yuasa one for £50, https://www.mdsbattery.co.uk/shop/produ ... oupID=9079
I've opted for the Yuasa YT19BL-BS. recommended for the R1200rt. And yes only £50 with free delivery.
Would be interested to know how the Yuasa (WET/AGM) battery works out.mentalrental wrote:I've opted for the Yuasa YT19BL-BS. recommended for the R1200rt.
Yes, it needs to be filled with acid, but is then sealed and maintenance free.
For £50, if there is any doubt, it's worth sticking a new battery on the bike.
The Exide (GEL/AGM) is factory sealed, ready for use, £60 from ebay.
I'd be happy to put acid in a battery to save a tenner.
Recently purchased a Yuasa dry charged, conventional flooded battery for the XJ650, it's not a big deal filling with acid.
Not forgetting a dry charged battery still should have a short period of charge before been used.David. wrote: I'd be happy to put acid in a battery to save a tenner.
At £50 each, you can buy three Yuasa batteries for the cost of one BMW (Exide) battery at £155, the fiver will more than cover the cost of leccy to charge them.
Oh, don't forget, that's a 3 x 1 year warranty too, only 2 years with BMW for the same £150/5.
My only comment is. Have you seen the mess a wet battery can make if the bike is dropped.
The Exide GEL battery for £60 would make a reasonable compromise over a wet battery (Yuasa for £50).
Gel Cell batteries contain a silica type gel that the battery electrolyte is suspended in, this thick paste like material allows electrons to flow between plates but will not leak from the battery if the case is broken.
At £60 each, that's £120 for a 2 year warranty or £155 for one BMW battery with a 2 year warranty.
- Has liked: 99 times
- Been liked: 223 times
David. wrote: The Exide GEL battery for £60 would make a reasonable compromise over a wet battery (Yuasa for £50).
I know which option I'll be choosing when I need a new battery! I might even buy a little Chinese BMW badge to stick on it with the saving
