2015 R1200Rt starting issue
jackhd
Post by jackhd »
Ever since I had my bike it does not start first time. If I turn off and on it starts right up.    Dealer said they cannot find anything wrong
Has anybody else had this issue?????
jackhd
Re: 2015 R1200Rt starting issue
Post by jackhd »
My model is a 2015 R1200RT. Keyless
This for the above post
johnesherman
Post by johnesherman »
For my 2016 R1200RTW I blip the throttle after ignition on but before hitting start button. Seems to improve ability to start time.
Sent from my SM-G935V using Tapatalk
John Sherman R1200RT Tacoma WA USA
jackhd
Post by jackhd »
Makes no difference if I flip throttle
Should fire up nearly immediately with no need to move the throttle.  Return to your dealer, go to a demo and show him the difference.
julianq
Post by julianq »
Side stand switch, took it off and cleaned it, problem went, same thing as you but if left a few seconds would start first time.
JQ 2007 R1200RT
jackhd
Post by jackhd »
I will try that
Jack
T6pilot
Post by T6pilot »
Jack
I'am going to throw this out, how old is the battery?
Others have reported problems when there batteries start getting weak
15 model it's possible your battery is 3 years old
Keep us posted
jackhd
Post by jackhd »
Battery is not the problem .
Not starting 1st time unless I turn off and on
It starts right up
Some time outside temp. Makes a difference.
LAF
Post by LAF »
Been many threads over many forums on this issue.
Seems all Voodoo to me.
Some say you need to use the kill button to shut down.
Some say the kickstand to shutdown.
Other say not allowing the dash to come fully up before starting the bike is the reason.
Also some have had this quirk since new others it came on after miles and others had it and it went away.
Just no rhyme to the reason.
Here is a primer for you.
http://www.bmwlt.com/forums/rt-series/145874-r1200rtw-cold-start-anomaly.html
JBnAZ
Post by JBnAZ »
Have observed same symptom, mine is intermittent. I found leaving the starter engaged for just slightly longer than I feel it should be engaged it starts on the first try. But as mentioned above, could just be a characteristic of the bike.
LAF
Post by LAF »
First ride today after setting cam timing.  I can say 100% the bike starts super strong on the 1st revolution.  I had been having trouble and even needing to push the button twice.  I never had this issue but it came on gradually over the last 4 or 5 months.
I can not say 100% what the cure was as I did 3 thrings that could have helped it.
One I set cam timing that was WAY off on left and off on right.
Second I changed plugs to iridium as all this work was a 12k.  I do not know if it is the iridium or just getting fresh plugs in.
Third I did clean and lube the side stand switch.
One of those I think had made the difference.
The lighting off of the motor is the best I can remember since owning the bike.
I say it was the timing and the plugs as they go hand in hand.
All I know is I am a happy camper with it now.
Paggers
Post by Paggers »
Great to hear that you have got it sorted. Now to get out there and enjoy it!
jackhd
Post by jackhd »
Would like to thank everybody giving advice about my starting issue
I no longer have a problem  since I always hit the kill switch before turning off ignition.
It now starts everything 1st time.
