Rubber care
timminator
Rubber care
Post by timminator »
What do you use to clean and preserve the rubber pieces on your RT?  I'm referring mostly to the dust boots on the swing-arm, but there are other flexible pieces as well.  The manual discourages the use of silicon-based products: "Rubber parts - Treat rubber parts with water or BMW rubber protection coating agent. ATTENTION - Use of silicone sprays for care of rubber seals. Damage to rubber seals. Do not use silicone sprays or care products that contain silicone."
BMW MOA #210438
Szibar
Re: Rubber care
Post by Szibar »
Silicone dissolves rubber, mate. That's why you use water-based lube with rubber ;)
Just low-pressure wash would do the trick.
What is your major malfunction, numbnuts!?
aweight
Re: Rubber care
Post by aweight »
I use ACF on all the rubber and black plastic, bring it up a treat
R1200RT LE San Marino Blue
Re: Rubber care
aweight wrote:I use ACF on all the rubber and black plastic, brings it up a treat.
Me too, plus any nuts, bolts or other fasteners can get a coating of ACF-50 from the oily rag whilst applying to the black areas.
ITB
Re: Rubber care
Post by ITB »
I use Gummi Pflege on my RT and on my cars' rubber seals.
https://www.amazon.com/nextzett-91480615-Gummi-Pflege-Rubber/dp/B004B8GTQG
B787MECH
Bike Model and Year: 2016 LC
Re: Rubber care
Post by B787MECH »
WD-40 Multi-Use works well and does not contain silicone.
