Removing adhesive residue from windscreen
pkpilot
Post by pkpilot »
I bought a 1200RT that the previous owner appeared to have attached and EZPass transponder to the windscreen.  There is adhesive residue on the inside of the windscreen that I would like to remove without damaging the plastic.  I know WD40 is good for removing residue from bumper stickers.  Any ideas on what I might use that will not damage the windscreen?
timminator
Re: Removing adhesive residue from windscreen
Post by timminator »
WD-40 is safe for plastic, but just be sure to clean it all off afterwards.  The residue can damage plastic over time especially in the sun.  Another safe alternative is mineral spirits, with the same caveats about cleanup afterwards.  A friend of mine swears by olive oil, and it's absolutely safe too.
BMW MOA #210438
pkpilot
Post by pkpilot »
timminator wrote: WD-40 is safe for plastic, but just be sure to clean it all off afterwards.  The residue can damage plastic over time especially in the sun.  Another safe alternative is mineral spirits, with the same caveats about cleanup afterwards.  A friend of mine swears by olive oil, and it's absolutely safe too.
Thanks!
exportman
Has liked: 10 times
Been liked: 47 times
Post by exportman »
Try Orange oil products  I have found these work
leonjennings
Post by leonjennings »
standard nail varnish removal fluid. perfect.
2012 SE
timminator
leonjennings wrote: standard nail varnish removal fluid. perfect.
If you mean acetone, I would not get that anywhere near plastic.  It works great on a chrome bumper, but not a plastic or painted surface. Maybe you have a different formula than we do, but in the states, nail polish remover is about 99% acetone.
BMW MOA #210438
Has liked: 99 times
Been liked: 224 times
Sticky Stuff Remover works a treat and won't harm any other surfaces. It has a nice smell of Citrus Fruits too  :)
http://www.ebay.co.uk/itm/De-Solv-it-St ... SwTA9X3Eg9
pkpilot
Post by pkpilot »
The WD-40 worked great. No issues whatsoever.
realshelby
Post by realshelby »
Don't ever get nail polish remover near a plastic windshield!
WD 40 can work, as the OP found. Just limit the amount of time it is on the screen. Wash with soap to completely remove it.
An eraser on a pencil, or for erasing pencil marks, can be a very good way to remove many kinds of adhesive.
DonVulpes
Post by DonVulpes »
Olive oil works really well too. Doesn't need to be anything special.
No matter where I'm going, getting there on two wheels is always best.
