Windscreen
Windscreen
Just changed my 2013 RT to a early 2016 RT LE, one feature is that when you switch off, the screen retracts to it's lowest position and automatically returns to it's previous position as you move off, I would like to disable this feature but can't spot the ability to do this in the menu's, does anyone know if it's possible to disable this or not.
Mondeoman
Re: Windscreen
mondeoman wrote: Just changed my 2013 RT to a early 2016 RT LE, one feature is that when you switch off, the screen retracts to it's lowest position and automatically returns to it's previous position as you move off, I would like to disable this feature but can't spot the ability to do this in the menu's, does anyone know if it's possible to disable this or not.
Why would you want to?
- Been liked: 21 times
Re: Windscreen
To clean the inside of the windscreen? - the answer is to turn on the ignition and raise the windscreen.
Re: Windscreen
+1
- smileymiley
- Has liked: 6 times
- Been liked: 11 times
Re: Windscreen
Re: Windscreen
mondeoman wrote: I'll have too then.
Yep. And as a bonus, you can listen to the radio at the same time (if you have it fitted - and have the 'speakers attached ...I took my 'speakers out to give me a load of storage space).
