Coolant Level
hammo
Been liked: 20 times
Coolant Level
Post by hammo »
Checked out my coolant level on my 2018 RTLE today what a job to see it !!!! does anyone else have the same problem ? can you put some type of dye in it to make it more visible !!!!
Sprintgull
Re: Coolant Level
Post by Sprintgull »
I use a torch!  As you say it is not easy to see.
Has liked: 237 times
Been liked: 107 times
Re: Coolant Level
Use torch as well shine from underneath.
Steve F
Re: Coolant Level
Post by Steve F »
Agreed, as BoB21 said above! Yes, it is a PITA to see ordinarily!
amsrk144
Re: Coolant Level
Post by amsrk144 »
Just checked yesterday.  I can't see the level even with a flashlight.  Shaking the bike doesn't help.  Spent 15 minutes taking the fairing off  (slowly so I don't break the stupid tab) and 5 seconds to check the coolant level.  It was at the max line.
Beagle
Re: Coolant Level
Post by Beagle »
You would think there would be some colour from whatever antifreeze it uses.
Sprintgull
Re: Coolant Level
.... or a level sensor!
