Hi Guys,
I'm sure this question has been asked before, however....on a 2014 R1200RT how do you switch the odometer display between miles and kilometers?
Easy to do on the Garmin GPS, but I can't remember how to change the motorcycle display....
Cheers
David
Changing display between Miles and Kms
Re: Changing display between Miles and Kms
Toaster wrote: Hi Guys,
Cheers
David
You can't. Dealer only or not sure if you can do it from a GS911
Casbar wrote: You can't. Dealer only or not sure if you can do it from a GS911
It's a pity this isn't possible without a GS-911, it means I can't change when going to / from mainland Europe. If I felt the need that is ..... ;D
This was one of my first moans about the bike when I got mine in 2014. Whats really annoying is that its just a few lines of code that could be easily be put into a software update to give us a menu item KM / Miles. Sometimes I don't understand BMW.
Do the newer bikes have a user way to do this ?
- Has liked: 88 times
- Been liked: 160 times
Levisp wrote: This was one of my first moans about the bike when I got mine in 2014. Whats really annoying is that its just a few lines of code that could be easily be put into a software update to give us a menu item KM / Miles. Sometimes I don't understand BMW.
My 2019 bike doesn't have the option. Just use the Nav V and set it to kilometres when I get over the water.
MikeS wrote: ..... Just use the Nav V and set it to kilometres when I get over the water.
Ditto
