BMW NAV VI ( 6 ) time error
davef1uk
Post by davef1uk »
Not sure if this is mine or others, but my say nav time which is gps run, is 3 minutes out of sinc.  I can’t correct it, override it so is it annoying.
My phone which is gps auto time is correct.  Dam sat nav isn’t.  Odd.  Hmmm
Motorbiking is a life, not a hobby.  Ride with Pride.  😜
Hors Piste
Re: BMW NAV VI ( 6 ) time error
Post by Hors Piste »
That's very odd - you can turn off the GPS auto time in settings, are you sure that you haven't done that?
davef1uk
Post by davef1uk »
I know I could turn it off, but then I would have to set the time manually each time or would it remember when I take it off?  Cheers
Been liked: 46 times
Davef1uk wrote: I know I could turn it off, but then I would have to set the time manually each time or would it remember when I take it off?  Cheers
Thats odd, just checked my Nav VI and it hasn't been on the bike for a couple of weeks and the time is 100% correct. I have the bike set to auto, so the Sat Nav updates the bikes time.
guest4915
Post by guest4915 »
Same here, time is accurate.
Hors Piste
As I understand it sat navs work by comparing time signals from different satellites, so for the gps time to be incorrect points to something very wrong indeed....
Has liked: 88 times
Been liked: 160 times
Factory reset? After backing up obviously.
I suppose it's worth a try
davef1uk
Post by davef1uk »
Ok i have turned it off. And time is good.  When I enable gps it’s again out by 3 mins ... some lazy bloody sat not doing good up there lol
