I've always had the service on my 2015 R1200RT done by a BMW certified shop, (West Side Motor Sports, Spokane, WA. USA). Since I live about a 3 hour drive/ride from the shop, I decided to do regular maintenance my self; oil and filter, air filter and final drive fluid change, spline lube. Simple stuff. Also have a GS-911 for fault examinations (works quite well).
Just got through changing the final drive fluid and discovered that, while the recommended replacement volume is, (by BMW) 180 ml for in service bikes, (no drive gear replacement, etc.) I just drained out only 45 ml. There was no sign of leakage and I had it on the recommended service schedule. Seems like the shop didn't put in the total volume that is recommended. Again, no leakage indicated over the past riding season, (about 1400 miles since last service). The drained fluid was a bit darker that the new fluid I put in and no particulate on the mag drain plug. Still.....one might want to beware of "authorized BMW mechanics" results. My lessons learned: double check and question so called shop experts and don't go back to West Side Motor Sports, Spokane, WA.
Cheers from the Okanogan Highlands of WA. State, USA.
Final Drive Maintenance
Re: Final Drive Maintenance
That must have been a very disappointing discovery.
Have you told the Service Manager ? He should know, and it would be interesting to hear his response.
Because it’s so darn easy, I change mine at each oil change
Do your bike a favor, check out DIMPLE MAGNETIC drain plugs
I run both the engine and final drive plugs
- Been liked: 476 times
The OE magnetic drain plug $20.17.paulgelineau wrote:No particulate on the magnetic drain plug.
The Dimple Magnetic Drain Plug is $35.95.T6pilot wrote:Check out DIMPLE MAGNETIC drain plugs.
for a r1200rt LC (mine's a 2015) is it M12x1.0 Magnetic Drain Plug for BMW Final Drive and
M20x1.5×12 Magnetic Drain Plug for the sump?
Yes, they are fitted as standard by BMW.Old-Git wrote:For an R1200RT LC (2015) is it M12 x 1.0 Magnetic Drain Plug for BMW Final Drive and M20 x 1.5 × 12 Magnetic Drain Plug for the sump?
I have a new to me 2016 RTW. Are the specs on the plugs consistent through the years? I live over 300 miles from my dealer!
Yes.jenatk wrote:I have a new to me 2016 RTW. Are the specs on the plugs consistent through the years?
Sump Plug, 01/2013 - 03/2019, https://www.realoem.com/bmw/enUS/part?i ... 1118530317
Final Drive Plug, 01/2013 - 03/2019, https://www.realoem.com/bmw/enUS/part?i ... 3117705854
